Go to Post But please take into account that each year, the GDC has to come up with a rule book that will spend the next three months being picked apart by 40,000 of the brightest, most creative minds on the planet. I think they do an outstanding job of it. - dtengineering [more]
Unread 08-01-2015, 22:29
hibbsconnor hibbsconnor is offline
Programmer
AKA: Connor Hibbs
FRC #2826 (WAVE ROBOTICS)
hibbsconnor is an unknown quantity at this point
Dispslay cout in Eclipse
Does anyone know how we can see what should be displayed with cout? We used the vx Works target server last year, but it is not available Eclipse for the 2015 year. We are trying Riolog but nothing shows up. Any help displaying any feedback from the RoboRIO would be greatly appreciated!
Unread 08-01-2015, 22:59
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Dispslay cout in Eclipse
Make sure that the network, and the subnet masks in particular, are set correctly. If you can, use the radio configuration tool to set up the dlink access point, then set your laptop and the roboRIO to DHCP. You should make sure that the subnet mask on the network interface you are using to connect to the robot is 255.255.255.0.
Brad Miller
Robotics Resource Center
Unread 11-01-2015, 09:40
dxc dxc is offline
FRC #1551
dxc is an unknown quantity at this point
we use printf and the output *does* show up in riolog. ordinarily std::cout and printf both write to stdout, but maybe this isn't the case here.
Unread 12-01-2015, 21:48
JohnM's Avatar
JohnM JohnM is offline
FRC #5854 (Glitch)
JohnM has a spectacular aura aboutJohnM has a spectacular aura about
Our team just did this today using a console out. I used a std:: out << "Whatever" << std::endl. Also make sure your driver station is enabled.
Unread 18-01-2015, 07:53
mdrouillard mdrouillard is offline
FRC #0772
mdrouillard is an unknown quantity at this point
We are also having this problem. We will check out subnet masks and report back. But for us now in Java the use of println does not seem to print to rio log. We are using the dashboard for output right now which works well.
Unread 19-01-2015, 12:51
AKA: Brad
There was a new update posted on Friday that fixes the buffering issue with RIOlog. It also fixes a number of other things and adds 2015 Vision examples for C++ and Java.
Brad Miller
Unread 19-01-2015, 22:38
JefferMC JefferMC is offline
AKA: Jeff Corbett
FRC #1319 (Flash)
JefferMC will become famous soon enough
I thought I saw a post stating there was an update, and there is a change log, but now I cannot find this update.
I'm hoping this update brings the C++ CANTalon up to parity with the Java library (I need to invert a slave CANTalon).
EDIT: Ah, the CPPandJava.ZIP file has been replaced with a new version (at http://first.wpi.edu/FRC/roborio/zipfile/). The instructions are the same.
Unread 22-01-2015, 07:27
FRC #0772
Thanks Brad. the one programming laptop indeed had the incorrect subnet mask. Riolog now working everyone.
so in summary, our radio is set as the DHCP server, with subnet 255.255.255.0 and both the rio, and connected pc/driverstation is now set to get ip address automatically via dhcp.
It works now.
Thanks.
Unread 23-01-2015, 22:40
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
Checkout section 21.15 of Talon software reference manual
http://www.crosstheroadelectronics.c...ol_system.html
Unread 25-01-2015, 13:32
AKA: Jeff Corbett
FRC #1319 (Flash)
Thank you for that. Yes, that addresses the issue.
But the Java libraries and the C++ libraries are supposed to be functionally equivalent, right? Why are they out of sync here?
