Go to Post Everyone is wrong! - Chris is me [more]
Unread 18-01-2015, 08:38
Re: Mecanum Polar Drive Help
Originally Posted by SoftwareRachel View Post
We had a similar problem the other day and the solution was that two of our motors needed to be inverted.
The procedure I described in post#3 allows you to determine which motors need to be inverted, and whether the PWM cables are going to the wrong ports/motors.
