Go to Post Temp wiring is always bad but it is made worse when dealing with a $1000 part. You wouldn't try to lash a makeshift power source to your PC. - Al Skierkiewicz [more]
Unread 04-03-2003, 18:57
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Fix my 120mhz Computer
I'm trying to fix up my 120mhz computer...
First thing that went wrong was monitor but that was easy.
What the problem is now is that the computer (running Windows 95) does not detect the cd-drive... Since it's windows 95, I go to the control panel, add hardware, detect, click add, but then it requires the Win95 install CD to get the right drivers/files for it... do you see the paradox in doing this? Yeah... so how can I get my cd drive to read? I know power is getting to it as I can open/close it.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 04-03-2003, 19:05
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
Make sure the IDE cable is connected properly.
If it is, and you need drives from Win95, try to find a floppy disk set of Win95 (or at least the drivers).
Or, if the comp has internet on it, I am sure you can find drivers on the net somewhere.
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 04-03-2003, 20:00
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
One word:
Milton.
Couldn't find a picture of the copier-beat-down scene, but I think you get the reference.
Seriously though, take the harddrive out, set it as a slave, put it in a computer that does work, then use that computer to copy all the 95 .cab files onto that harddrive.
That and why are you trying to fix a 120mhz in the first place?
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 04-03-2003, 21:21
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
why are you trying to use win95? at least, use 98, it's actually somewhat stable . well, after you get the cd-rom working by dan's method, that is.
one test though, if the computer can boot from the CD-ROM, try putting a cd in, and booting from the CD-ROM. if that fails, it's something outside of windows, if that works, you have to fix windows.
AIM --> Woloi
Email --> ian@woloschin.com
My computer loves Microsoft ARGH!! HELP ME! team222badbrad Chit-Chat 12 29-01-2005 09:17
Best computer game specs MarkF Chit-Chat 3 15-04-2003 14:59
List of UTC Hartford Teams archiver 2001 3 24-06-2002 01:09
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
My other computer will not work with this forum! David Kelso CD Forum Support 4 04-06-2001 21:52
