Go to Post Relax. Have fun. Enjoy the improvements. Build what you want to. - Rich Kressly [more]
Unread 18-01-2015, 09:40
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
how to identify roboRIO
We have a need to determine the unique roboRIO our code is running on; our test robot does not have a PCM, so we don't want to enable pneumatics if it's running on the test box so we don't flood the console with the CAN timeout errors?
Has anyone hit on a good way to determine the identity of the roboRIO (serial #, or name?)
We're working off the MAC addresses of the network interfaces right now, which is fine, but was curious if anyone had done it a different way.
Unread 18-01-2015, 11:01
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: how to identify roboRIO
I think I would put a switch on a digital input, or just a pigtail of wire that connects the input to ground. If it reads a false, then its execute code accordingly.
Brian K
Team 1225 Robotics Mentor
Unread 18-01-2015, 11:34
fovea1959's Avatar
AKA: Doug Wegscheid
That's a better idea than our thought of going off the roboRIO id. Doing it your way, if we have to swap roboRIOs, then we don't need to touch code, just make sure the "I am a test chassis" jumper is NOT in place. When I read this, I first thought of putting a "I am the competition chassis" jumper in place, but if the jumper got lost, then we'd lose time making up one at a competition, so "I am a test chassis" it is. I suspect we'll have enough DIO to get us by....
My curiousity *is* piqued, though, so if anyone has a way to do it, I'm interested. I remember that it was possible to pull the serial number from LabVIEW. I suspect they never put the appropriate 'hook' into wpilibj to expose that functionality, though I suspect a clever person with the right documentation could pull it off using HALUtil and friends....
Unread 18-01-2015, 20:53
You can use the team number to differentiate. http://wpilib.screenstepslive.com/s/...015#TeamNumber
Unread 18-01-2015, 22:06
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
You could also just use the Preferences class with an enablePcm boolean variable.
Unread 19-01-2015, 09:20
fovea1959's Avatar
AKA: Doug Wegscheid
Joe, Thomas, thanks...
