The year robots stand still
Everyone is calling this the year of the mecanum wheel but to me that sounds like teams who are not prepared to program for mecanums are going to use them and end up not moving much. What do you guys think?
Re: The year robots stand still
Also, teams have 6 weeks to build and program their robot. (Okay, the programming is usually the last week or so...) I have confidence that 99% of the teams attempting mecanum, will be able to move. |
Move, maybe. Move well, not so sure.
Most of the teams with mecanum drive will be able to move, but few will use the strafing ability effectively and frequently.
Pretty much par for the course, then.
Ditto...especially in light of the higher than normal potential for unbalanced weight distribution.
#7
Even if teams can't get omni directional code working, you can still put normal tank drive code on to drive around normally.
#8
This is why we decided not to use mech wheels this year. We were confident that we could get the code to work, but with the potential to be heavily off balance front to back ( loaded and unloaded) we figured the chances of getting strafe to work well weren't good enough to chance it. |
#9
I thought this thread would be about robots designed to stand still.
Holonomic and field-centric in LabView took us less than two hours to program. Needed a gyro to work well, but a strong team should be able help get a rookie moving. |
#10
Practice makes these omni drives useful. A good drive train is only as good as its driver. Practice, Practice, and more Practice. The weight will be more undistributed this year and the possibility of one wheel leaving the ground if you go over the ramp.
#11
I also thought this would be about robots designed to not drive. Will someone please start that thread? |
#12
