Go to Post I guess my only option is to either stop picking on Dave or come up with an even better picture! Now, which one do you think I'll choose? - MissInformation [more]
Unread 17-01-2015, 15:13
chmorroni chmorroni is offline
chmorroni
AKA: Christopher Morroni
FRC #3729
chmorroni is on a distinguished road
Motor Control Rules
I have been looking for a while, but I can't find answers to the couple questions we have.
Firstly, can we control multiple (2) motors from one PWM output on the roboRIO? This wouold either be done with a PWM splitter or by connecting 2 motors to one motor controller/spike.
Also, R57 states that "Every relay module, servo, and PWM motor controller shall be connected to a corresponding port." We have, in the past, used PWM outputs to control Spikes, but I am getting the impression that this is illegal per R57. Is my logic correct, or can we still use PWM outputs to control Spikes?
Unread 17-01-2015, 16:01
Re: Motor Control Rules
You can do it with a PWM splitter cable. Only certain motors may be "doubled up" on a single speed controller; see Table 4-4 under <R42>.
I do not believe you have ever controlled a Spike using a PWM output. The signals are not compatible. Spike relays are controlled using relay outputs.
Unread 17-01-2015, 16:56
chmorroni
FRC #3729
In my interpretation of R59, "both may not be wired simultaneously on the same device," is that a PWM splitter would be legal.
Really? I could have sworn we have used something other than relay ports in the past.
Unread 17-01-2015, 21:11
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
Once we used a DIO channel for a spike for our compressor, which iirc resulted in the normal compressor code not working and the spike turning off when we told it to go on and vice-versa. 0/5 stars, do not recommend.
Ratpack programming lead 2013 - 2015
ἔκλαγξαν δ᾽ ἄρ᾽ ὀϊστοὶ ἐπ᾽ ὤμων χωομένοιο / αὐτοῦ κινηθέντος: ὃ δ᾽ ἤϊε νυκτὶ ἐοικώς. (Ancient Greek nerds unite!)
Unread 17-01-2015, 21:26
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Spike outputs happen to work on three wires, just like standard PWM cables. However, they are not the same sort of signal inside the wire. PWM is pulse-width modulation; it's a way of actually carrying a digital signal. The relays use one of the wires as ground and the other two as ground-power to control the two outputs on the relay module.
TL;DR:
Cables are the same, carried signals are not.
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 18-01-2015, 11:48
chmorroni
FRC #3729
That must be what I was remembering. Is there a way to get this to work reliably?
Unread 18-01-2015, 11:56
There's no way to get it to work legally...
Unread 18-01-2015, 12:59
Chris,
R42 is the defining rule here which includes table 4-4. You can split PWM control to feed multiple controllers if you wish. I recommend no more than two personally. The table also lists which motors can be paralleled to work with a single controller. There is a down side to that in that the current limit must be split between the two motors. The PWM control used for motor controllers is the same control for servos provided you make the jumper to supply the required voltage.
Unread 18-01-2015, 13:11
Why?
BTW, does anyone have the specs for the PWM input current draw for the new 2015 motor controllers?
Unread 18-01-2015, 13:15
Ether, I know there is a limit to how many loads can be placed on the PWM ( I don't remember it off the top of my head) output but more than two makes it hard to diagnose an issue. Should a wayward metal part crimp one of the PWM wires and short the leads, you end up loosing a lot.
