Go to Post One must agree that a Bus full of FIRSTers is always Fun'n Frolic. :) - RoboMadi [more]
Unread 10-01-2015, 14:14
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Need 2014 Driver Station Software
Could anyone please send me the installation or zip file of the driver station software for 2014? The links on NI seem to be down, namely this one. My team will be in your eternal debt.
Unread 10-01-2015, 14:37
freaksdesign freaksdesign is offline
freaksdesign is an unknown quantity at this point
Re: Need 2014 Driver Station Software
See if this will help you, it should have the downloads that you need
https://decibel.ni.com/content/docs/DOC-34731
Unread 10-01-2015, 14:48
FRC #1747
That document has been updated for 2015. But in the comments, I saw the Update Suite 6.0 on there, but when I ran it, it didn't actually install the old driver station. That's why I was kind of hoping someone would just zip up their executable (I'm like 80% sure they're portable like that).
Unread 10-01-2015, 14:58
That document has been update for 2015. But in the comments, I saw the Update Suite 6.0 on there, but when I ran it, it didn't actually install the old driver station. That's why I was kind of hoping someone would just zip up their executable (I'm like 80% they're portable like that).
Oh sorry I miss read. If you are just trying to run old code/robot you should be able to switch to the old protocols. see below
Unread 10-01-2015, 15:42
FRC #1747
huh, and I'm assuming that it still uses the old image (v52) and the same static IPs as last year? Also, the code is in Java, which I'm seeing in some threads that IDEs don't support for v57.
Unread 13-01-2015, 14:28
Flyte's Avatar
Flyte Flyte is offline
FRC #1787 (Flying Circuits)
Flyte is an unknown quantity at this point
If anyone has it I would also like the 2014 driver station.
We tried using the new driver station but our code is also Java and we just can't get it to work. Everything is fine except the robot code will not connect.
Thanks
Unread 13-01-2015, 14:42
Here is the 2014 Driver Station.
You will probably be queried as to where the .dll's are.
They are in the data folder.
Unread 13-01-2015, 14:45
Flyte's Avatar
Thanks
Unread 18-01-2015, 13:30
S1nus S1nus is offline
FRC #1757
S1nus is an unknown quantity at this point
Hi there, if anyone is reading this, we're looking for the whole 2014 update suite. We need the imaging tool, etc. Thank you
Unread 18-01-2015, 13:36
http://download.ni.com/support/softl...eSuite6.00.zip
Unread 19-01-2015, 22:58
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Could you explain exactly what I need to do to run last year's robot from the new driver station software (I'm not sure what the arrow in your image means)? We tried today and didn't know what we had to change...then we were afraid to update the drivers' station laptop for fear of losing the ability to drive the '14 bot.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 20-01-2015, 09:09
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The switch freak is pointing to lets the 2015 DS interface with the 2014 FMS. My understanding is the 2015 will not talk to the 2014 robots. Apparently the switch that allowed it to run 2014 comms in the Beta testing was dropped. My programmer tells me the 2014 DS will run on the 2015 system. I have not actually seen how he tested this. Maybe somebody more versed in Lab View will comment. (The DS is a labview program regardless of what language your robot is programed in.)
Unread 21-01-2015, 08:51
The 2014 and 2015 DS have different EXE names. I do not have both installed on my laptop, and I don't control the installers, so I can't say much about what that will do, but the programs can coexist with no problem. Each has its own set of DLLs and a reference to a LV runtime.
The 2015 DS can actually control 4 slot cRIOs that have been updated to 2015 image. Those cRIOs will then speak the 2015 protocol.
The 2015 DS and roboRIO can also speak the old protocol, but this was turned off during the beta in order to avoid misconfiguration.
So in order to better answer your question, do you intend to update last year's robot to this years development tools and image? Is it a 4-slot?
If not, I'd lean towards zipping the old c:\Program Files\FRC Driver Station folder, then installing the new one, then unzipping the old one into a folder something like 2014 FRC Driver Station.
Greg McKaskle
Unread 21-01-2015, 09:31
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Greg McKaskle
Boy that is really going to confuse the Demo drivers. 8 slot, 4 slot 2014, 4 slot 2015. For the hard headed Java programmers, Can you put the 2015 image on the 4 slots? Presumably you would still use the 2014 net-bean plugins? Or we just shouldn't go there?
Unread 21-01-2015, 10:43
Sounds like a job for documentation. Or at least a checklist.
As for Java dependencies. I'm not the right person to comment on that. I know that the cRIO will still need Squawk JVM and that the language changed enough that the libraries are not that compatible. I would guess that a new 2015 image on a cRIO 4 slot will still run fine with older Java tools, but I'd wait for a beta team or WPI student to confirm.
Greg McKaskle
