Go to Post I am definitely not a battery or battery charging expert (far from it) but I do know enough to be dangerous (I stayed in a Holiday Inn Express last night)... - Don Wright [more]
Unread 18-01-2015, 13:10
andyman64 andyman64 is offline
Active FRC Member
FRC #3466 (Vikings)
Rookie Year: 2015
andyman64 is an unknown quantity at this point
Talons Problem
For some reason when i turn my robot to teleop mode only one side of my robots talon motor controllers starts working and the other set just starts blinking.Any ideas?
Unread 18-01-2015, 13:25
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Talons Problem
Are you using PWM or CAN to control the Talons? Can you post your code? Does your robot work fine in autonomous?
1771- Programmer, Captain, Drive Team (2009-2012)
4509- Mentor (2013-2015)
1771- Mentor (2015)
Unread 18-01-2015, 14:14
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
Re: Talons Problem
Have you calibrated all 4 talons? Usually "phantom signals" are attributed to calibration issues.
Academic Student (Forever)
Unread 18-01-2015, 18:46
Re: Talons Problem
You say the nonworking pair of Talons "starts" blinking when you enable the robot. What are they doing when the robot is disabled?
