Go to Post our electronics boards had begun to look like we'd planted a wire bush and it grew - daltore [more]
Unread 18-01-2015, 13:46
Arbalest007 Arbalest007 is offline
FRC #2496
Arbalest007 is an unknown quantity at this point
RoboRIO RIOLog in Eclipse Broken! Help!
Hi everyone! I am the new programmer for my team this year, and I just set up Eclipse and all the FRC plugins. I have successfully programmed our roboRIO practice bot, as well as run it. In the past few days, rioLog on Eclipse was working and would give me output for statements in my code where I had "System.out.println" statements. However, just today and yesterday, I have been unable to get any output from the rioLog on Eclipse to help get values from the motors, joystick, etc. Would anyone happen to know why the rioLog seems to have broke down and how I can reset it on Eclipse to work again? Thanks!
Unread 18-01-2015, 14:00
Darkseer54's Avatar
Darkseer54 Darkseer54 is offline
Former Controls Captain and Driver
AKA: Zach Kaplan
FRC #1086 (Blue Cheese)
Darkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of light
Re: RoboRIO RIOLog in Eclipse Broken! Help!
Are you using the latest update for eclipse from WPI? That seemed to fix our problems with RIOlog.
Unread 18-01-2015, 14:11
FRC #2496
Yes. I'm using all of the 2015 FRC Update Driver Station software too. The thing is, everything was working fine just a few days ago when I wrote the code - outputs were recorded perfectly in the rioLog. Yet now when I try to get output from the print statements in my code in rioLog nothing happens. IDK what happened.
Unread 18-01-2015, 14:13
FRC #2496
Actually Darkseer, scrap that. I did not see there was a new update to Eclipse from WPI. I will update and post if the rioLog issue is fixed
Unread 18-01-2015, 14:19
FRC #2496
I just updated Eclipse with the recent update from WPI. Still no response from the rioLog. Should I just reinstall the 2015 Update Software and reinstall Eclipse and see if that fixes the problem?
Unread 18-01-2015, 14:30
Darkseer54's Avatar
AKA: Zach Kaplan
Couple of things you could check first: Make sure your firewall is off (we had that issue as well), and check out your subnet mask. It should be 255.255.255.0 . If it is not then go in and manually change it to that. If that doesn't help then I'd have to (unfortunately) recommend that you do uninstall and reinstall and see if that works. I'd suggest you post before doing this though.
EDIT: Also, not to be patronising, but check your settings for RIOlog and make sure you are accepting packets and such.
Unread 18-01-2015, 14:34
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
We've noticed sometimes if you disconnect then reconnect to the wireless network, the RIOLog magically comes to life.
I.e. after we send code and expect output on the log and get nothing, we'll disconnect from the 610 wireless network, then reconnect. When the connection comes back, we see our output start showing up.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 18-01-2015, 15:08
FRC #2496
Hi. So here's what I have done so far. I reinstalled the Driver Station and other utilities. Reinstalled the WPI Plugin in Eclipse. Set my IP Address on my adapter to 10.24.96.51. Set subnet to 255.255.255.0. Turned Windows Firewall off. Disconnected after uploading code and connected again as Mr. Lim suggested. Still no output coming from rioLOG.
Unread 18-01-2015, 16:06
Darkseer54's Avatar
AKA: Zach Kaplan
Did you recently reimage your roborio? If so did you have the log out on? Also, did you check the settings for RIOlog?
Unread 18-01-2015, 20:12
FRC #2496
I re-imaged it yesterday to make sure I had all the connection and Bridge Configuration set up correctly. Was there something I did not check in the Imaging Utility to let the RioLog work?
Unread 18-01-2015, 20:41
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
Here's the issue I'm having, the RioLog option isn't available for me in show view under general. (running on a mac)
  • I updated eclipse
  • I updated to Java 8
  • I have automatic updates for plugins enabled
  • I restarted eclipse
I'm lost and don't know what else to do. Any help is appreciated.
I win! XD
Unread 18-01-2015, 21:01
Darkseer54's Avatar
AKA: Zach Kaplan
Arbalest007 - There should be something in the imaging tool along the lines of console out or log out. Check to make sure you have that checked. Also make sure that in RIOlog all the settings are set to accepting feedback, and not pause or anything like that.
Schnabel - Did you install the FRC toolchain? That's the only thing I can think of that would be the problem. If you have, just go through the steps for installing again and make sure you follow them line by line. Its a pain, but two days ago I had a problem simply from installing them in the wrong order.
Unread 19-01-2015, 01:02
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
  • I updated eclipse
Did you deinstall previous versions of Java or just install Java 8? It may be that eclipse is still using Java 7. The riolog is only available if Eclipse's runtime environment is Java 8.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 19-01-2015, 10:01
MamaSpoldi's Avatar
MamaSpoldi MamaSpoldi is online now
Programming Mentor
AKA: Laura Spoldi
FRC #0230 (Gaelhawks)
MamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant futureMamaSpoldi has a brilliant future
If you are connecting wirelessly to the roboRIO, I believe you should be set for DHCP (meaning you should have selected "Obtain IP address automatically") instead of setting a specific IP address based on your team number as we had to do in the past. I feel like the communications instructions are not very definitive because they don't give you a specific line-by-line list of what to set, but this works for us.
Unread 19-01-2015, 19:10
Schnabel's Avatar
AKA: Eric Schnabel
FRC #0469
I believe I am good here. I did follow the instructions when I installed originally and am able to deploy code.
I did not uninstall Java 7, but looking at my runtime configuration Java 7 isn't an option available any more, I'll look into this further (thanks for the tip).
Edit: Just forced an uninstall of Java, reinstalled and still no luck.
Network adapter is set to DHCP, mDNS is resolving correctly. I would look into this further if I couldn't connect, but I can't get the option to show up in eclipse to add to my view.
Thanks again all!
I win! XD
