Go to Post Ahhh. The Grammar Fairy strikes again! - Cynette [more]
Unread 18-01-2015, 15:10
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Voltage readout wiring
I was looking on amazon last night and I found a voltage readout display for 4.5v to 30v. My question is, where would be the best spot to plug it into on the PDP?
This is the display.
I would like to inform every one that my team does have a "battery beak" for checking battery voltage and that this is more or less a just for fun thing for our robot.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 18-01-2015, 15:13
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Voltage readout wiring
We used one last year and they are very useful. You can either plug one into a breaker spot (20amp breaker would be fine or smaller) or if you already have a custom circuit being powered you can use a terminal block and plug into that. We plugged ours into the same circuit that powered our LED lights.
Unread 18-01-2015, 15:16
Munchskull's Avatar
Team Role: CAD
Thank you. In I was hoping some one from your team would respond. You guys are the insperation to use it.
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 20-01-2015, 07:28
Anthony,
Allen was pointing out that you must wire through a breaker to provide protection should the device or the wiring short. You can use a smaller breaker, i.e. 5 amps, if this is the only load.
Unread 20-01-2015, 08:43
philso philso is offline
FRC #2587
Please note that "Battery Beak" is a trade name that refers to an instrument with a particular set of functions; measuring battery voltage AND internal impedance under load. The voltmeter you are intending to install only measures the battery voltage so calling it a "battery beak" will cause confusion.
Unread 20-01-2015, 09:23
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Ok, so lets read his post again:
Bolding is mine. I'm reading that Munchskull has a Battery Beak (tm) and is looking to add a small display on the robot. So they are good to go.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 20-01-2015, 13:22
FRC #2587
Thanks, Foster. It's nice to know you are fully awake.
