Go to Post You will find we are more talkative in about 5 1/2 weeks. ;) - mrnoble [more]
Unread 18-01-2015, 17:00
tomsgarage tomsgarage is offline
FRC #5230
tomsgarage is an unknown quantity at this point
closed center solenoid valves legal??
We're wanting to design using closed center, three position valves, for double acting cylinders. Anyone know if that might be legal?? Also last year I was thinking that we were required to provide one manual ball valve to release the pressure on everything on the robot. Is this still a requirement - I can't seem to find where this requirement is/was documented.
Unread 18-01-2015, 17:09
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Re: closed center solenoid valves legal??
Please section 4.10, R67, R72 and for visual Figure 4-7. That will take care of your pressure vent and many other questions.
As for the centre tap plug that may require a Q&A question.
Unread 18-01-2015, 19:34
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
R67 requires a pressure vent plug.
R78 requires the pressure vent plug to vent ALL stored pressure when actuated.
I don't think a block center valve will dump any upstream air volume unless one of the solenoids on the valve are energized. For this reason, I don't believe this valve will satisfy R78.
Note that when the robot us disabled, all relay outputs are de-energized (causing the valve to center and prevent air from venting).
http://team2168.org
