Go to Post This is a pure blooded, man and machine versus man and machine, brain versus brain, driving skill challenge. - Andy Grady [more]
Unread 18-01-2015, 17:17
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
How to use a fifth drive motor with RobotPy?
Hi! We hit a problem with our robot code. We got it to drive with a normal chassis that has one motor on each side like a tank. But now we want to use our new Omni wheels(http://upload.wikimedia.org/wikipedi...77_3727729.jpg) with one motor on each side and then one in the middle perpendicular to the other motors so we can strafe sideways. Anyways, our problem is how do we set the fifth motor(The one perpendicular to the side motors) to be the x-axis on the controller. We also need the side motors to only be able to go forward or backward(y-axis). We are using a joystick for the controls. Thanks a bunch in advance!
Unread 18-01-2015, 18:27
x86_4819's Avatar
x86_4819 x86_4819 is offline
computer-whisperer
AKA: Christian Balcom
FRC #4819 (Flat Mountain Mechanics)
x86_4819 is on a distinguished road
Re: How to use a fifth drive motor with RobotPy?
To do this you will need to do the following:
Initialize the new motor controller object in robotInit():
self.slide_motor = wpilib.Talon(INSERT_PORT_NUMBER_HERE)
If your motor controller is something other than a Talon, you will need to adjust accordingly.
Use the x-axis of the Joystick to control the motor in teleopPeriodic():
self.slide_motor.set(self.joystick.getX())
I hope this works for you!
My Github Repositories
Unread 18-01-2015, 18:34
team-4480's Avatar
Debug? What's that?
FRC #4480
So then for the side motors, it would be
self.side_motor.set(self.joystick.getY())
? We will try it Monday!
