[FTC]: dual synchronized servos or geared up winch servo?
The kids have ball dumper that is controlled by a quarter-scale HS-785HB servo. Apparently the dumper is a little heavy, as the spline on the servo stripped (it may have not been properly seated, which may have contributed).
With a competition coming up this weekend and the girls also on an FRC team, there isn't time for a full redesign of something that was working pretty well. There seems to be two options we've discussed that might work: (1) buy two HS-755HB servos, put them on opposite sides of the ball dumper, and synchronize them. (2) buy a HS-785HB winch servo (3.5 rotations) and gear it up. On #1, we are afraid that if they don't sync perfectly there will be problems (they may fight each other). On #2, we are afraid of gear slippage because it need some amount of precision. Anyone have experience with either option? Or other thoughts? Thanks! |
Re: [FTC]: dual synchronized servos or geared up winch servo?
I would suggest option #1 - Provided they are programmed correctly, you shouldn't have any issue syncing them up.
I vote for #1 also.
Another thing that could work depending on if your design has room is to add a counter-weight on the opposite side of the ball dumper. That would decrease the overall torque that the servo would have to provide. |
Thanks for the quick replies. We went with #1, and the servos should arrive by Tuesday evening. The dumper/loader is already pretty well balanced (it tilts at the middle, and has standard servos at both ends to load and unload, but those contribute to the weight).
The backstory on this is that the dumper was working okay with a lower-torque standard servo, but it was pretty strained and seemed like it would break at any time, so we got one with 4 times the torque figuring that it would have no problem. However, they mounted it with a top-mount bracket and there were screws on the back of the servo horn that were rubbing against the mount each time it turned. Additionally, I think it was only pressed halfway down on the spline, so it was easier to strip half the spline than the whole spline. I guess those top-mount Tetrix servo brackets aren't meant for use with actual servos because the clearance isn't large enough to attach anything to them! Ours now has a nice, larger hole to prevent rubbing.(We might be able to get away with one, given that fix, but two seems so much safer for a critical component of the robot.) |
BSV,
I would not be surprised if the servos do not link up. You will need some kind of mechanical device to link them together and remember that you can't simply turn one around and switch the power lead to get it to go in the other direction as you could with a motor. Some kind of spring linkage might work if they do not seem to follow each other close enough for your application. |
We are thinking that "servo2 = 255 - servo1" given that both of them start at the same (mirrored) position, and that we'd have to always make sure they are initialized properly or we will run into issues where they are fighting each other. |
#7
I would power up the robot with the two servos not connected to each other. Then I would command them to move and observe the reaction of each compared to the other. Observe jitter when the servo reaches commanded position. A flex coupling might be all that is needed.
#8
I would have to search around. I would check with hobby outlets and see what they might have.
#10
Maybe how about using two LEGO motors (ports B and C) as they try to naturally sync when you apply the same power to them (PID control kept by the NXT). If you're using ROBOTC, I think they keep it that way as well in the firmware as does the LabVIEW version does.
#11
So maybe a block of rubber with holes punched into it would work?
We'll run some tests on the servos when they come in. May have to improvise a little. Thanks! |
#12
Got the servos today, and they aren't an exact match, but a "sleep(10)" delay between start times syncs them perfectly.
The loading tray that both of these support also has some flexibility, and we did find some flexible couplings in the Tetrix supply, so I think we are good to go. Thanks to everyone for your feedback. |
#13
So, we got through the tournament, and everything worked fine.
Then, today, both servos stripped out their splines doing something routine. At least that looks to be the case, as the kids haven't had time to take everything apart again. We are thinking of our next option, the same servo with the gearbox from servo city. Anyone had experience with these? https://www.servocity.com/html/spg78...o_gearbox.html Thanks! -------- Edit: Maybe not. All the info we can find on the winch servo is that no one has had much luck controlling it precisely in RobotC. Last edited by BSV : 26-01-2015 at 22:33. |
#14
https://www.servocity.com/html/servoblocks.html keeps things aligned, has a real bearing & support... |
#15
