Go to Post if you do make a marshmallow robot, that would be pretty sweet. - smurfgirl [more]
Unread 18-01-2015, 22:48
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Ekocycle 3D Printer
My FTC team finally got there Ekocycle 3D printer a few days ago and I finally got around to testing it before I let the students go wild with it. I am using Auto CAD Inventor 2014. I made a simple test cube, the dimensions being 0.5" x 0.5" x 0.5". I save the assembly file then I converted it to a .stl file so that I could upload it to the Cubify program and transfer it to the Ekocycle printer. When I went to print the test cube it asked me if the file was saved in inches or millimeters. I chose inches and noticed that it said the dimensions of my cube was 1.34" x 1.34" x 1.34". I printed the file thinking it was an error never the less the piece came out at the wrong size. I went back and check the measurements in the .slt file and the cube was 0.5" x 0.5" x 0.5". Any suggestions as to what I am doing wrong?
Unread 18-01-2015, 22:55
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Re: Ekocycle 3D Printer
Double check what dimensions are getting output by Inventor 2014. Just because the part was built in units of inches doesn't mean the .stl output was inches. When you save the file:
Export-->CAD File, select .stl, then click "Options". Ensure "Units" is inches or mm, not cm
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 18-01-2015, 23:10
To export I went under File ->Export -> CAD File then I use the drop down and hit .stl. Is there another way of exporting that I am missing?
Unread 18-01-2015, 23:12
Oh I see it now! I was exporting in centimeters. Silly me... Thanks for the help.
Unread 19-01-2015, 10:32
jman4747's Avatar
jman4747 jman4747 is online now
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
I tried converting to .STL by that method, and even with the units correct in the .ipt it still up-scaled the part. Inventor has a tool just for generating .STL's for 3D printing.
See this post: http://www.chiefdelphi.com/forums/sh...7&postcount=43
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
