Go to Post I bet a lot of us (mentors and students) got into this line of work first because we wondered how things work, and stayed in it because we thought "I can make that work better". Thus starts a life-long battle between perfection and time. So far, time is ahead. - petek [more]
Unread 11-01-2015, 00:46
team2161's Avatar
team2161 team2161 is offline
FRC #2161
team2161 is an unknown quantity at this point
Exclamation Labview 2015 joystick help!
Hello my name is Justin lead programmer for the Walt Whitman RoboCats in Huntington Station, NY. I recently started programming with the new labview software for the RoboRIO. I am so used to unbundling by name for the joystick buttons and axis, i have no idea how to program using an index array. How would i set up a tank drive configuration using the index array and set up a relay to a button on an xbox controller.
Thanks.
Unread 11-01-2015, 00:55
Re: Labview 2015 joystick help!
Have you seen this? http://wpilib.screenstepslive.com/s/...e-2014-to-2015
Unread 11-01-2015, 08:19
Additionally, the robot template code contains a simple teleop that indexes the first two axes from a single joystick/game controller and send it to the arcade driving. In most respects, it is the same. The index array is a growable node. You can wire in a number to each row, telling it what element to return, or if left unwired, it will increment based on the previous row.
Greg McKaskle
Unread 17-01-2015, 18:52
Jack Gillespie's Avatar
Jack Gillespie Jack Gillespie is offline
FRC #5430 (Pirate Robolution)
Jack Gillespie is an unknown quantity at this point
there are three arrays axis,buttons,POV. What does POV stand for?
Unread 17-01-2015, 19:55
POV=Point of View
It's often called the hat on a game controller.
It's the one that looks like a cross.
Unread 18-01-2015, 23:35
FrankenmuthK's Avatar
FrankenmuthK FrankenmuthK is offline
FRC #5215
FrankenmuthK is an unknown quantity at this point
Originally Posted by Mark McLeod View Post
POV=Point of View
Do you happen to have a screen shot of what the drive code should look like for the 360?
Unread 19-01-2015, 06:56
The drive code for TeleOp takes whichever joystick axes you intend to use, potentially scales or conditions them, and sends them to RobotDrive.
Assuming you have a skid-steer robot such as the KoP, the first decision is whether you want a tank, where left and right axes drive the left and right wheels directly much like a tank, a bobcat, or a bulldozer. Or whether you want two generally orthogonal axes that are mixed to determine the left and right motor speeds. This feels much more like video game joystick driving with left/right inputs steering and forward/back inputs going front and back.
Once you have decided that, choose which axes from the 360 controller that you want to use. It may be useful to use the USB tab of the DS to identify the numbers. Then on the TeleOp diagram, index out those elements from the Axes array. Wire those into the RobotDrive that you choose to use.
Greg McKaskle
Unread 19-01-2015, 08:41
Here's an example using Axis 1 & 5 to tank drive with an xBox contoller.
Unread 20-01-2015, 13:18
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Mark,
Do you have a similiar picture for the F310 Logitech gamepad controller?
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 20-01-2015, 14:00
The code is the same. The only difference is the number of the axis you want to read. The Driver Station will show you which axis (and button and POV) number responds when you manipulate the gamepad.
Choose the USB tab at the left, and select the gamepad in the list. The axes and buttons will show up to the right of the selected controller.
Unread 20-01-2015, 14:30
Mark,
A set of game controller mappings are at:
http://www.team358.org/files/program...019/#joysticks
The F310 has a couple of optional settings.
Unread 21-01-2015, 15:32
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
A problem I ran into last night, is the xbox controller, has 10 buttons from 0-9, but in the code the button array only has 9 elements from 0-8 . . .
So how do we program control on button9...
Sorry to highjack thread, but this seem a fitting place to ask the question.
Started New Thread, please follow here. http://www.chiefdelphi.com/forums/sh...72&postcount=1
The sooner we get behind schedule, the more time we have to catch up.
Unread 21-01-2015, 21:01
Charles Ononye Charles Ononye is offline
FRC #2346 (Cel-Techs)
Charles Ononye is an unknown quantity at this point
Here you go:
In case anyone was wondering, you can use an array to cluster converter to connect to unbundle by name to get your buttons.
Unread 05-03-2016, 13:13
Pugsly Pugsly is offline
FRC #1370
Pugsly is an unknown quantity at this point
Regarding the "Set Output" of the joystick I am trying to light up an indicator using the Launchpad that was included in last years kit and I can't for the life of me figure out how to wire this up in Labview.
So say for instance I want to light a LED on the launchpad Red or Blue depending on what alliance we are on. Anyone have any ideas on how do do that?
