Go to Post As a team leader if I do not INSPIRE I have failed, and I do not like to fail. - Mike Martus [more]
Unread 18-01-2015, 15:12
Trey178's Avatar
Trey178 Trey178 is offline
M.C. in Training
AKA: Trevor
FRC #0178 (2nd Law Enforcers)
Trey178 is an unknown quantity at this point
Tape Measure Container Grabber
For Ultimate Ascent, one CT team had a climbing system that used a set of hooks deployed via tape measure. Now we have idea to use a similar mechanism to grab the recycling containers off the step without moving the totes in the landfill. Having it be directly driven off a Banebots motor, with a 12:1 gear ratio, gave decent retraction but not much else.
My question to the readers is this: what suggestions do you have for controlling a tape measure so it does not kink when it rolls in or out?
Mentor & Alumnus of Team 178 - 2012-present
M.C. in Training
Unread 18-01-2015, 21:04
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is online now
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Tape Measure Container Grabber
For starters, If you are committed to this, the Stanley Fatmax Xtreme will probably give you the best chance of success. It is the most rigid tape measure that I know of.
As far as avoiding collapse is concerned, joining 2 parallel tapes at the ends so that they can't twist would help.
Also, since sharp kinking tends to permanently damage the blade, once kinking does occur, replacement of the tape could reduce the risk of it happening again.
Good luck.
Unread 18-01-2015, 21:11
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
Spectrum has a similar idea for containers.
They posted some details on their blog.
Head Programmer / Driver
Unread 18-01-2015, 21:29
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
https://www.youtube.com/watch?v=b-1wx_xZ8tA
my favorite robot I ever had a hand in building. check out "sewer tape" it works well for this application.
Unread 18-01-2015, 23:45
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Team Role: CAD
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
If I understand correctly, sewer tape is just a thin strip of metal that can be extended out in a loop without sagging?
Unread 19-01-2015, 00:39
Samwaldo's Avatar
Samwaldo Samwaldo is offline
College Student / Between Teams
Samwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to behold
The team you are refering to is 2064. Their technical mentor was a technology teacher at my High School so i got to hear and see quite alot of that design
Im pretty sure that the 2 hooks they used were riveted to tape measures that without side loads are very strong. They were each ran off of window motors. A ball was pushed against the curved part of the tape so that it stayed alligned and bent less. (Not sure if that makes sense)
Overall was it the best design? It had its flaws especially the fact that the tape measures when touched or vibrated enough would collapse. At Where's Wolcott our team chose 1511 and them. As the #7 alliance we made it to the finals due to the fact that we timed out when each robot would climb another level since 1511's slams would vibrate the pyramid to much for the tape measures.
Team 1099, The DiscoTechs, 10' - 14'
Driver 11' - 14'................Team Captain 13' - 14'
University of Hartford Class of 2018, Mechanical Engineer
2015 & 2016 NE District Volunteer
Unread 19-01-2015, 07:33
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Whenever anyone talks about tape measures the first team that comes to mind is FRC3280 the RhodeRebels. They used a tape measure back in 2010 to climb. I'm sure that you could contact them, I remember at Boston they had a display/cutaway of the mechanism in their pit.
Unread 19-01-2015, 07:50
wilsonmw04's Avatar
Coach
Exactly, it worked very well for us. We used the 1/8" thick tape that year but it comes in 1/16" as well.
Unread 19-01-2015, 21:28
Trey178's Avatar
M.C. in Training
AKA: Trevor
Saw the video and I like the concept. Did some searching and it looks like it comes packaged on its own reel/spool. Could 2106 have assembled the mechanism so that it's directly driven, or belt/chain driven?
M.C. in Training
Unread 20-01-2015, 00:03
wilsonmw04's Avatar
Coach
We cut the length we needed from the roll and made our own measuring tape holder:
http://www.chiefdelphi.com/media/img...18989dfe_l.jpg
Unread 20-01-2015, 01:07
Tristan Lall's Avatar
Tristan Lall Tristan Lall is online now
FRC #0188 (Woburn Robotics)
Tape measures were a common accessory in 2002 (to expand the robot size to occupy a zone while scoring in another). They were typically powered by an external drive wheel off of a drill motor and transmission (roughly equivalent to the current RS-775 motors), or by direct drive (sacrificing the retraction mechanism by driving the hub directly).
However, kink-resistance wasn't typically a huge deal (except when teams decided to try to get entangled and draw a penalty by driving back and forth on an opponent's tape measure), so teams simply relied upon the inherent stiffness of the tape measure.
You might want to investigate whether it works better with the numbers facing up, or down. Also consider having quickly installable spares, because if it is damaged during one match, odds are it will kink at the site of the damage (if anywhere) during subsequent matches.
Unread 20-01-2015, 08:45
Back after 4 years off
FRC #5279
I don't believe 3280 is competing this year, and the Engineers involved have moved on to other teams. I worked with them that year and would be happy to answer questions.
Here is a picture of the spare we had in the pit in Boston
http://www.chiefdelphi.com/forums/sh...highlight=3280
And Here is a picture of the device in action.
As PAR_WIG1350 said the Stanley Fat Max Xtreme is they way to go, or at least was in 2010. He also hit it on the head about kinking, buy multiple tape measures, and prep the tapes so they can be quickly swapped out.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 20-01-2015, 17:29
Trey178's Avatar
M.C. in Training
AKA: Trevor
In order for this mechanism to work, one end of the tape needed to be attached to the frame. Where and how was it secured?
For the tape itself, did you remove it from the stock reel or use it as part of the assembly?
M.C. in Training
Unread 20-01-2015, 21:43
wilsonmw04's Avatar
Coach
I believe we used a hinge and bolted it to the frame.
Unread 21-01-2015, 07:41
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
There was a video of a DARPA robot I saw some years ago that used three tapes slaved together to create a triangular beam. This was used as a camera pole for a very short surveillance robot. I believe the robot was only 6 inches tall, but the "pole" could extend up 10 to 15 feet.
