Go to Post This could be interesting...rednecks of FIRST unite for duct tape - amos229 [more]
Unread 19-01-2015, 09:04
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: pic: Good use of a old cRio
When those came out jaws were dropping... you laugh at them now... but back then they were revolutionary compared to the old IFI controllers of yesteryear.
Unread 19-01-2015, 10:24
calvinpanho calvinpanho is offline
#383 Coach
AKA: Calvin S. Panho
FRC #0383 (Brazilian Machine)
calvinpanho will become famous soon enough
Originally Posted by Alan Anderson View Post
Last year's NI LabVIEW for FRC still creates programs; it does not expire. The driver station still works. We're using one of the 8-slot cRIOs for a mecanum testbed.
The 4-slot cRIOs are currently supported with this year's LabVIEW.
the Windriver(C++) license it's almost over, do you know if the new software (eclipse) is capable of programming cRio?
FIRST - Simplifying ways, broadening horizons!
Unread 19-01-2015, 13:42
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
I do not know, i doubt it though.
I do know that the old java tools still work just fine, but netbeans is free software, so that kind of explains Java.
Unread 19-01-2015, 14:03
chmconkling's Avatar
chmconkling chmconkling is offline
Jack of all groups. Master at most.
AKA: chris
FRC #2363 (Triple Helix)
chmconkling is an unknown quantity at this point
Yes and WPI and FIRST Technical Resources says to install eclipse
Unread 19-01-2015, 14:31
#383 Coach
Thanks! But, how about the driver station, its possible to use with the new one? or i need to use an old version?
Unread 19-01-2015, 14:42
Can you provide the link to the instructions for using eclipse for programming C++ for the cRIO?
Unread 19-01-2015, 20:22
rockychat3 rockychat3 is offline
FRC #4859
rockychat3 is an unknown quantity at this point
We have been holding off on buying a second RoboRIO, but I had a few questions on ways we could save money. For context, we have two old 4-slot cRIOs no longer on working robots and we use Java. All of the students have only 2015 tools (Labview update and Eclipse) installed, but I have held back on upgrading software in case I am the only one who can still connect to a cRIO.
(1) Is it possible to have two versions of drivers station on the same PC?
(2) Is it possible to program the cRIO from Netbeans with the old plugins and the RoboRIO from Eclipse with the new plugins on the same PC?
(3) If we did buy a new RoboRIO, could we use a standard 20AMP slot on the old PDP to power it, saving us $200 on a new PDP (for internal/prototyping, not for competition)?
As a low to mid-budget team, I don't want to throw around that kind of money if we can get nearly the same benefit for less. Thanks
-andy / 4859
Unread 19-01-2015, 20:28
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
This is actually not true.
I don't have acess to a 4-slot crio but the current 2015 driver station should work with 4-slot cRIOs.
For the 2015 driver station to work, go to the 3rd tab on the left (the gear), and change the FMS protocol from '15 to 09' to '14
You should then be able to connect to the 4 slot cRIO.
I hope this helps.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 19-01-2015, 20:36
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
I hope this helps.
Despite that misleading switch, you are actually unable to use the new DS with the to control cRIOs running old code. See this thread for more information.
I believe it is possible to install this year's labview code on to the cRIO and allow it to use the 2015 protocol, but this doesn't work for other languages.
Unread 19-01-2015, 20:38
AKA: Roger Moore
I thought I saw something that said this.
We only have 8-slot cRIOs so we have to use the old driver station anyways.
Stronghold
Student 2013-2016
Unread 19-01-2015, 21:33
AKA: Sparks
http://wpilib.screenstepslive.com/s/...-all-languages
This update includes the driver station. Seeing as the first step is "uninstall old versions", I seriously doubt you can have both driver stations on the same PC, but perhaps it would be okay if you had them on different profiles. I have not tried this. I recommend getting a super cheap XP laptop someone probably has lying around for a cRIO driver station.
This does indeed work. I've done it. You might spend a fair amount of time screwing with network settings, but if you're using a roboRIO, you probably will anyway.
I have not tried this, but my gut feeling is that you'll run into some troubles because the old PDP isn't CAN enabled and the new one is, as is the roboRIO. The roboRIO might get confused without the PDP on CAN, plus you couldn't do any current monitoring.
Unread 19-01-2015, 22:51
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
The new roboRIO will function without the CAN feature of the PDP. It just won't have current-sense features. You will still be able to deploy code, debug, move motors, etc....
The roboRIO doesn't need the PDP CAN to function, it just needs battery voltage to power. To your point it wouldn't be legal but the question was for internal/prototyping, so you should be fine.
