Go to Post Let's leave the football uniforms at home though, teams. ... The last thing I want to see is Baker in Brett Favre yellow spandex... *shudder* - Amanda Morrison [more]
Unread 19-01-2015, 03:46
achen15 achen15 is offline
FRC #4990
achen15 is an unknown quantity at this point
Re: Timing belt elevators
Originally Posted by seg9585 View Post
Yes, we did (for chain)! Here's a video of our engineering model:
https://www.youtube.com/watch?v=idJFSad9gCA
(maybe this is a general question but)
How do you attach the carriage to a chain loop?
Unread 19-01-2015, 03:54
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
A lot people have used screws, I know.
Unread 19-01-2015, 12:26
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
Originally Posted by Mike Marandola View Post
Has anyone successfully 3D printed a timing belt clamp? I was thinking about trying that out.
We printed a couple this weekend. We haven't properly tested them yet, but they seem like they'll work.
Unread 19-01-2015, 12:55
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
I made a couple of timing belt clamps in 2011 for Logomotion when we used a length Gates belt to drive the upper stage of a compound elevator. 10-15 minutes work with a hacksaw and files. It worked perfectly. Use a square to transfer the spacing from a belt to a piece of flat aluminum. Cut slots to depth with a hack saw. Clean up with a small 3 square file and/or needle files. An advantage over the purchase version referred to above was that the clamp plate had bolt holes to the sides so they didn't interfere with or damage the belt.
My views do not necessarily reflect those of FIRST Robotics
George Chisholm
2003-2015 Founding Mentor FRC 1334 The Red Devils
2011 Woodie Flowers Finalist, Waterloo Regional
2015-Founding Mentor FRC 1360 Orbit Robotics
Unread 19-01-2015, 13:30
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
We are using M3 screws through holes in the #25 chain links. The other option I considered was using chain half-links, but figured maintenance would be easier and the build would generally be more reliable with closed loop chain
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 19-01-2015, 13:35
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
These are useful.
ANSI Roller Chain Attachment Links
EDIT: 250th Post!
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 19-01-2015, 15:29
Jaywalker1711's Avatar
Jaywalker1711 Jaywalker1711 is offline
Registered Dinosaur
AKA: RJ
FRC #1711 (Raptors)
Team Role: Human Player
Jaywalker1711 is a jewel in the roughJaywalker1711 is a jewel in the roughJaywalker1711 is a jewel in the rough
What timing belts are you guys using, and where are you ordering them from?
We are having difficulty finding stock 12' timing belts
Unread 19-01-2015, 16:15
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
The longest I know of is 250T which is 250 teeth at 5mm per is 1250mm or 49" (just over 4ft). If you cut the belt and use the single sided mounting you could go nearly 4', but not 12' (or 6'). If you really need that travel, it may be simplest to switch to chain.
Unread 19-01-2015, 16:31
Pendulum^-1's Avatar
Pendulum^-1 Pendulum^-1 is offline
AKA: Jim Grove
FRC #1915 (Firebird Robotics)
Pendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nice
We got 30' of 25 mm wide belt from polybelt.com. We will cut to length. A bit pricey, sure.
Jim Grove, Mentor
firebirds1915.blogspot.com
(2007-2017) 1915, McKinley Tech HS, Washington, DC
(2009) 2932, Mid-Pac Institute, Honolulu, HI (Rookie Season)
(2011) 2425, Hillsborough HS, Tampa, FL
(2013-2015) 4464, College Park, MD, 2013 Rookie All Star Winner and 2014 Regional Champions, Washington, DC
FIRST is not rocket science. But it is like drinking from a fire hose.
Unread 19-01-2015, 16:42
AdamHeard's Avatar
Lead Mentor
For round tooth profiles plates can get slotted with a ball end mill very easily to make clamps.
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
You can also buy HTD belt or GT2 belt by the meter from SDP-SI
Unread 19-01-2015, 16:54
Drew4564 Drew4564 is offline
It's Tape Measure Time!
FRC #4564 (Orange Chaos)
Team Role: Driver
Drew4564 is an unknown quantity at this point
My team ordered some 3800 millimeter (about 12.45 feet) long, 15 mm wide belts from Motion Industries.
You can check them out here if you're interested.
Team 4564, Orange Chaos
2013-2016: Mechanical Leader, CAD Leader, Driver and Dean's List Finalist (NEDCMP 2015)
2013: Rookie All Star Award and Curie Division 8th Seed Alliance Captain
2014: Gracious Professionalism Award and Innovation in Control Award
2015: Pine Tree #1 Seed and Champion, 2x Innovation in Control Award, #Buttongate Victim
2016: WPI #1 Seed, NEDCMP #1 Seed and Finalists, Excellence in Engineering Award, Creativty Award
Unread 27-01-2015, 20:55
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Here is a test of our 3d printed belt clamp. It was printed on a Cube printer with PLA.
The plan is to have the printed piece epoxied to the aluminum plate on the bottom and the top plate will do the clamping.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
