Go to Post Basically, just because you CAN do something doesn't mean you should and being savvy enough doesn't entitle you to being above the law. - Greg Needel [more]
Unread 19-01-2015, 18:27
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: What is wrong with my RobotPy code?
Recommend that you use the pyfrc simulator to test your code. Your problem will be immediately apparent when you actually run it.
To use the pyfrc simulator, get pyfrc installed and just run 'robot.py sim'.
When uploading the code to the robot, to see the output from your code (which would also show your problem), specify the --nc parameter to 'robot.py deploy' and it will launch a netconsole listener, which will show the output from your code.
You might benefit from the RobotPy eclipse plugins that we just released, it makes running tests and such a lot easier.
