Go to Post But now we know what's inside Shaun's backpack! ...Don Rotolo's plastic egg. - MishraArtificer [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.33 average. Display Modes
Unread 19-01-2015, 16:41
TheMechanic40 TheMechanic40 is offline
FRC #3506 (YETI Robotics)
TheMechanic40 is an unknown quantity at this point
How to print to the console in eclipse java programming FRC 2015
In past years my team, 3506, has used netbeans to programs our robots, but with the addition of the roborio we have been forced to switch to using Eclipse. We shortly found out that you can't print to the console (at least not obviously) and we are stuck with printing to the SmartDashboard which none of us fully understand. I should mention that we are using a command based robot so one of our problems with the SmartDashboard is we do not always know which of the many classes we should use to put the data. Does anyone know if it is possible to print to the console, or something else, or where we should use SmartDashboard?
Unread 19-01-2015, 16:51
Darkseer54's Avatar
Darkseer54 Darkseer54 is offline
Former Controls Captain and Driver
AKA: Zach Kaplan
FRC #1086 (Blue Cheese)
Darkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of lightDarkseer54 is a glorious beacon of light
Re: How to print to the console in eclipse java programming FRC 2015
Hi TheMechanic40, instead of the NetConsole that was used last year, the roboRIO uses RIOlog.
Installation instructions are found here. It prints basically the same way that NetConsole did, but you must have eclipse open to use it. A few teams have been having trouble with it, but after a bit of tinkering it usually works.
Hope this helps!
Zach
Unread 19-01-2015, 16:54
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
Can you post the section of code you are trying to output using the CODE (# on the editor) brackets?
Unread 19-01-2015, 17:26
Hope this helps!
Zach
Yes this works perfectly! Thank you for the information.
Unread 19-01-2015, 18:29
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Netconsole and rioLog actually use the same protocol. If you had netconsole installed from previous years, it should still work with the current robot.
