Go to Post Someday I will have to learn how tagging and reps work. I already know how search and brain farts work. - kstl99 [more]
Thread Tools Rating: Thread Rating: 29 votes, 5.00 average. Display Modes
Unread 19-01-2015, 18:43
Trevor4004 Trevor4004 is offline
FRC #4004
Trevor4004 is an unknown quantity at this point
Re: ANNOUNCING: navX MXP Robotics Navigation Sensor
My team recently received our navX board and we are very excited about the possibilities it will give us. However, the power LED on the RoboRio turns a solid red when we plug it directly into the MXP area of the RoboRio as described in the Plug-n-Play section of the navx-mxp wiki (https://code.google.com/p/navx-mxp/wiki/RoboRioInstall). The RoboRio User Manual says that a solid red for the power LED means "Fault condition detected. One or more user voltage rails are in short-circuit or overcurrent condition."
Our first thought was that the short-circuit or overcurrent problems were due to some strange interaction between the naxv board connecting to the RoboRio via MXP and our daisy chain going from the RoboRio to the PDP and containing 4 talon srxs and the PCM. But this doesn't seem to make a lot of sense considering this board is supposed to be designed to work with the RoboRio for FRC and a daisy chain of 4 talons and the PCM seems like a common setup in FRC.
We can still connect to the robot with out driver station, and we get full communication and robot code when we do. We are able to drive the robot around normally, but we are worried about trying to test the navx in our code until we can determine why the RoboRio is detecting a short-circuit or overcurrent condition. Any insight into why the RoboRio is detecting these problems would be greatly appreciated. Thank you.
