Go to Post Announcers don't keep the score. They are fairly outgoing people, make witty remarks, and wear goofy shirts. We can't take them too seriously. :) - Andy Baker [more]
Unread 19-01-2015, 16:40
team-4480's Avatar
team-4480 team-4480 is offline
Debug? What's that?
FRC #4480
team-4480 will become famous soon enoughteam-4480 will become famous soon enough
How to use Xbox controller with RobotPy?
Hi! So we have our code working with the Xbox controller's left joystick but that was just using the
self.stick=wpilib.Joystick(0)
and we can't figure out how to use the right joystick with it. Any help would be greatly appreciated!
Unread 19-01-2015, 18:20
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: How to use Xbox controller with RobotPy?
Recommend you search the forums, as your problem is a WPILib problem, and not necessarily specific to RobotPy.
Here's one that looks useful: http://www.chiefdelphi.com/forums/sh...highlight=xbox
Unread 19-01-2015, 18:36
team-4480's Avatar
Debug? What's that?
FRC #4480
After so more research, it seems like I have to make a AxisType Class and then put in what each axis is? Thanks for the response!
Unread 19-01-2015, 19:11
virtuald's Avatar
RobotPy Guy
Yeah, the docs aren't super clear on that, I'll need to update. When AxisType is specified, what it really means is pass in one of the constants that is defined in the class, or you can also just pass in a number. So something like...
joystick = wpilib.Joystick(0)
rightX = joystick.getAxis(4)
rightY = joystick.getAxis(5)
That might work. It might not.
Unread 19-01-2015, 19:17
Nunez4296's Avatar
Nunez4296 Nunez4296 is offline
Programmer
AKA: Joseph Nuņez
FRC #4296 (Trident Robotics)
Nunez4296 is an unknown quantity at this point
From the looks of it, your code is only written for one axis, axis 0. That is most likely the reason why only the left side is working. Go to the driver station with your controller plugged in and then to the USB panel. There you will find the connected joystick and all the buttons. Any button you press or joystick you move will show you the associated button value that you should implement into the code. remember that these are all array values, so you start with axis 0 and button 0.
Unread 19-01-2015, 20:30
team-4480's Avatar
Debug? What's that?
FRC #4480
Thanks to both of you for the help and I will try it tomorrow!
Unread 20-01-2015, 17:33
team-4480's Avatar
Debug? What's that?
FRC #4480
The joystick didn't work sadly. Is that the best way to do it or is there other ways? Thanks!
Unread 20-01-2015, 18:22
virtuald's Avatar
RobotPy Guy
I would see what code people are using in other languages, and translate it to python. It's definitely a WPILib related issue, so presumably someone else has had the problem too and fixed it.
I don't have an XBox, so I can't test it personally.
Unread 20-01-2015, 19:20
team-4480's Avatar
Debug? What's that?
FRC #4480
Just a quick side question, how can you use one motor and one axis for aracadeDrive? I tried just using the ".set()" but that didn't work. Thanks again for all your help!
Unread 20-01-2015, 20:22
virtuald's Avatar
RobotPy Guy
I'm not quite sure what you mean. If you want to set a single motor:
motor = wpilib.Talon(2)
motor.set(joystick.getX())
Unread 20-01-2015, 20:35
team-4480's Avatar
Debug? What's that?
FRC #4480
Do the motor.set and things like that have to be in the Teleop function to work properly? Thanks!
Unread 20-01-2015, 20:47
virtuald's Avatar
RobotPy Guy
The roboRIO will disable motors when the robot is not enabled, so I would not recommend setting the motors outside of teleop/autonomous modes.
