Go to Post Thermodynamics says that offense is harder than defense. - dtengineering [more]
Unread 19-01-2015, 21:37
Lightfoot26's Avatar
Lightfoot26 Lightfoot26 is offline
Just Out For A Rip, Bud...
AKA: Seth Lightfoot
FRC #1625 (Winnovation)
Lightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really nice
Re: Drive System Control Compensation
I don't know how much this applies, (when you say more control over acceleration this just jumped to my mind) but we created an acceleration rate limiter ("ramping" function) to ramp acceleration when the driver jams full speed on the joysticks (this helps with current spikes and wheel slip among other things). You can adjust your max desired slope which is the variable Slope_a and move the joystick slider to simulate joystick movement. There is an indicator of the motor output labeled "motor" as well. The graph will show you the joystick value (white line) in comparison with the motor output (red line). The smaller Slope_a is the longer it takes the motor to reach the full desired speed. When controlling finer movements, these curves overlap exactly. Here is the LabVIEW VI if you want to take a look. (Sorry if it is a little messy!) If you aren't too versed in LV, I'd be happy to explain more, if you have problems with the link let me know.
Winnovation Team 1625 (2010-??)
  • Electrical/Programming Captain (2011-2013)
  • Auxiliary Driver (2012-2013)
  • Team Captain (2013)
  • Alumni (Graduated May 2013)
  • Electrical and Programming Mentor (2014-??)
Unread 20-01-2015, 00:27
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Thanks. That sounds like what we are looking for.
I'll try to find a machine that still has LabView on it. (We've completely switched to C++.)
The Talon SRX also has a ramp builtin. We'll do some experiments with the ramping functions there as well. Might as well use all the processors we have on board. :-)
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 20-01-2015, 01:22
josesantos's Avatar
josesantos josesantos is offline
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
I've implemented ramping speed filters in RobotC using this example from one of our old programming leads. Essentially, the filter adds to the current speed the different between the current speed and the desired speed divided by some "alpha". This "smooths out" any motor speed changes.
So basically:
speed = speed + (joystick - speed)/alpha
Note that in his example, he multiplies then divides by an arbitrarily large value. I'm told he did this because the controller either didn't support floats or did floating point calculations much more slowly.
CAMS Robotics, FIRST Team 687 The Nerd Herd 2010-Present
College Mentor 2013-Present // Design Chairman 2012-2013
Berkeley High Robotics, FIRST Team 5499 2014-Present
College Mentor 2014-Present
