Go to Post Maybe someone should start a FIRST Anonymous meeting to try to help the tragicly addicted... - BiTurboS4 [more]
Unread 19-01-2015, 18:23
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
pic: What Are We Doing?
Unread 19-01-2015, 18:24
thatprogrammer's Avatar
thatprogrammer thatprogrammer is offline
AKA: Ahad Bawany
no team (None)
thatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond reputethatprogrammer has a reputation beyond repute
Re: pic: What Are We Doing?
Are you building a second chassis that runs of the power of the first? A larger version of the "minibot"? :O
Unread 19-01-2015, 18:35
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
My guess:
You are building two different robots.
1. Is a 4WD drive that stacks outside of the frame
2. Is a 6WD drive that stacks within the frame
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 19-01-2015, 18:38
AKA: Ahad Bawany
no team (None)
Originally Posted by orangemoore View Post
My guess:
Maybe the two chassis go in front of eachother after the match starts? You'd need a crazy system to lower one though...
Unread 19-01-2015, 18:43
Paul Richardson Paul Richardson is offline
Strategy/Mechanical/Drive Coach
no team (1477/3320)
Paul Richardson has a spectacular aura aboutPaul Richardson has a spectacular aura about
Transport configuration size restrictions do not apply once you're on the field setting up. You can just do it by hand, as long as you don't delay the match (guideline is you should be able to do it in a minute or less).
Unread 19-01-2015, 18:46
AKA: Ahad Bawany
no team (None)
True, but you need to transport within the normal size box. Fitting all of that into the box might be a bit.. difficult to transport with. If you could though, I can see how you could use fasteners to attach them together within 60 seconds. That might help lower your center of gravity as well...
Unread 19-01-2015, 20:11
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
I'm assuming you know the answer and didn't just wander into the work space and see that laid out.
If that is what you walked in on uh sorry I guess....
Am I only allowed to use the picture to guess?
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 19-01-2015, 20:56
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
I would suspect weight would turn into an issue if they planned to use both at the same time, My bet is they want to try both and have 2 complete robots bagged just in case.
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
Unread 19-01-2015, 21:42
samfruth's Avatar
samfruth samfruth is offline
FRC #1710 (Ravonics Revolution)
Team Role: Driver
samfruth will become famous soon enough
Are you building a robot by chance?
Unread 19-01-2015, 22:39
audietron's Avatar
Now that you mention it, I'm not so sure they are!
Unread 20-01-2015, 12:21
Chirag's Avatar
Chirag Chirag is offline
Alumni, now Remote Mentor (?)
AKA: Chirag Patel
FRC #4761 (Robockets)
Chirag is an unknown quantity at this point
A tethered, 2 part robot? I really wanted my team to do this but we decided against it. If that is what you guys are doing, I can't wait to see how it turns out!
_______________________________________________
The Robockets 4761
Student (2013 - 2015), Mechanical Lead (2014), Tech. Co-President (2015)
2014 - RIDE Winners (with 125 and 78)
2013 - Boston Regional Rookie All-Star and Highest Rookie Seed
http://www.robockets.org/
https://www.facebook.com/FrcTeam4761
https://www.twitter.com/FRC4761
Unread 20-01-2015, 12:43
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
the squarer (is that a word?) is the drive chassis - looks like drive mounting holes and bumper flares, and the tall one is the elevator - "wheels" mounted sideways for the lift mechanism. If I am correct, I recommend moving your battery location - would be long wire runs and very top heavy.
Unread 20-01-2015, 13:57
Jared Russell's Avatar
Taking a year (mostly) off
I hope you guys are doing what I think you are doing.
Unread 20-01-2015, 14:09
PayneTrain's Avatar
PayneTrain PayneTrain is online now
Trickle-Down CMP Allocation
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I hope they're doing what you think they're doing too, especially if we are thinking the same thing. It would also be cool if y'all are doing it.
Unread 20-01-2015, 14:35
