Go to Post The trick is to train the rest of the team to blame electrical instead. - Al3+ [more]
Unread 17-01-2015, 10:52
Re: Any Good Battery Chargers?
Originally Posted by adciv View Post
Alternatively, you can clamp the wire on a KOP battery cable and electrical tape the clamps.
That's stretching the meaning of "installed" a bit too far, in my opinion.
Unread 17-01-2015, 12:35
Amar Shah Amar Shah is offline
FRC #1899 (Saints Robotics)
Team Role: CAD
Amar Shah has a spectacular aura aboutAmar Shah has a spectacular aura aboutAmar Shah has a spectacular aura about
Perhaps. We also did that at one point when we were using a borrowed charger and could not remove the clamps.
Unread 17-01-2015, 13:16
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
Throwing in my support for the 3-bank charger. Both of my teams have used them and have had no issues (of my knowledge). Very satisfied.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 17-01-2015, 18:35
2508electronics 2508electronics is offline
The One Man Electrical Team
FRC #2508 (Armada Robotics)
Team Role: Electrical
2508electronics is an unknown quantity at this point
My team had 3 of the KoP ones and they have all started failing, however we bought the Andymark 3 battery charger and I love that thing. I've built it into a rolling cart and put all the batteries on top with the charger laying on the second shelf and it works great. It is also much faster than the KoP ones too.
Unread 20-01-2015, 00:17
baumgartensam's Avatar
baumgartensam baumgartensam is offline
AKA: Sam Baumgarten
FRC #0751 (Barn2Robotics)
baumgartensam will become famous soon enough
We switched over to this charger last year and I would highly recommend it. It is much nicer to have just one power cord and to not have the jumble of wired with multiple single battery chargers.
Unread 20-01-2015, 07:41
You can't beat a smart charger designed for SLA batteries with a max output current of 6 amps per output. There are a few that have five or six outputs of five amps each that work fine. Smart chargers will modify the output current throughout the charge cycle and will automatically stop the charge cycle or switch to a low trickle when fully charged.
Please remember that although the charger is only able to supply 6 amps, the battery that it is connected to has the ability to supply more than 500 amps when charged. That potential is available at any improperly insulated connections that you supply on the charger side. This is a common mistake that teams make. It is also the reason for the rule this year because burning wires have resulted in the past.
