Go to Post I can follow directions, but if it's not in the directions, I'm lost. - rclothier [more]
Unread 20-01-2015, 11:15
waldohatesyou waldohatesyou is offline
FRC #3705
waldohatesyou is an unknown quantity at this point
FRC- Sensor Help
Hi there, i have been trying to code a couple of sensors for our FRC robot.
hall effect sensor and an pontentiometer. unfortunately it hasnt been working; does anyone have any sample code in C++?
Unread 20-01-2015, 11:18
marshall's Avatar
marshall marshall is offline
FRC #0900 (The Zebracorns)
Re: FRC- Sensor Help
You should post what code you have along with how you have the sensors setup physically as well. What specific problems are you running into?
Unread 20-01-2015, 11:19
Depending on your application, Hall Effect sensor typically uses the counter object in WPILib.
Potentiometer uses analog input.
The more detail you provide, the more detailed the answers you get will be.
Unread 20-01-2015, 11:37
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Depending on your application, Hall Effect sensor typically uses the counter object in WPILib.......
Another possibility that goes with "Depending on your application", a Hall Effect Sensor could be set up as a simple limit switch. In this case, it would be a "simple digital input".
