Go to Post Often when discussing GP, the P half gets forgotten. - Taylor [more]
Unread 20-01-2015, 12:04
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Fixing Toughbox Nano assembly inconsistancies
We recently got some Toughbox Nanos from AndyMark and noticed that after we switched the output shafts that some of them could no longer be turned by hand when a CIM was installed. I tweaked the tightness of some of the CIM mounting screws and occasionally saw this problem disappear. On one I loosened the center bearing retainer screws (seen below) so that they no longer contacted the bearing, and I was able to spin the shaft by hand again.
It is a weird intermittent problem, but the difference in gearbox operation has me worried about how consistent our drivetrain will be. Intermittent problems like this have cause huge headaches for us in the past and we would love to find a reliable way to fix this. I'm hoping that this is a type of problem that experienced teams know how to work around, or know the cause of.
Can anyone offer ideas, suggestions, or even guesses as to what we can try to fix this? Thanks in advance.
Unread 20-01-2015, 12:14
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Fixing gearbox assembly inconsistancies
Have you guys talked to AndyMark yet? They would be the best people to advise you and they are very quick to respond.
1058 PVC Pirates 2016 - xxxx
Unread 20-01-2015, 12:37
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
The two middle gears have a hub spacer on one side and not on the other. Make sure the two flat sides are against each other and the two spacer sides are pushing on the inner races of the bearings.
Other than that, there should not be an issue with the retaining screws being a bit loose.
We had problems last year with a student who held the box in a vice while she worked on it and introduced a bow that caused the CIM motor not to mesh well when its screws were tightened. We wound up shimming the motor to reduce the gear engagement.
Unread 20-01-2015, 12:59
oison75's Avatar
oison75 oison75 is offline
Bag of Water
FRC #0751
oison75 is an unknown quantity at this point
In the past, we've also had some issues with aluminum vs. steel gears. Aluminum gears tend to warp under pressure and get jammed, while steel gears don't. (Keep in mind this was with a 3-CIM Andy Mark gearbox and not the toughbox nano).
Unread 20-01-2015, 13:26
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
What aluminum gears? VEXPro?
We've used aluminum gears extensively from VEXPro and ones we custom made...never seen one "warp under pressure and get jammed".
It is highly likely you had another issue that was independent of the gear. For sure more information is needed before making a blanket statement that aluminum gears are worse than steel.
2001-2004: Team 100
2006-Present: Team 254
Unread 20-01-2015, 13:30
FRC #1559
Since the topic of aluminum gears came up, we used VEXpro gears last year in what was a punishing game. We had no issues. That said, the VEXpro gears have the above mentioned spacers on BOTH sides of their gears and are therefore wider than the AM gears. We machined off one of the spacers and again we oriented the gears flat side to flat side.
Unread 20-01-2015, 13:34
Monochron's Avatar
Engineering Mentor
Yeah, I doubled checked that the middle gears were oriented this way, no problems there. As far as I could tell only one gearbox reacted differently to loose or tight retaining screws, the rest just won't spin by hand regardless of screw tightness.
Dissembly and reassembly would often allow me to turn one by hand, but I haven't found a method that works every time.
Jrizo's Avatar
Jrizo Jrizo is offline
FRC #4335 (Metallic Clouds)
Jrizo is an unknown quantity at this point
Check to make sure your CIM mounting screws are not to long. That can cause The tuff box nano to not want to turn. Also check to make sure that the bearings did not get reversed.
Unread 20-01-2015, 14:29
StealthMentor StealthMentor is offline
FRC #1802
StealthMentor is an unknown quantity at this point
We sent two back this year one for a gear that the bore was broached crooked, and the other was not the right width causing a lot of slop. The ones we got as replacement where fine but the included kit to mount the gear to the CIM with the two washers below the gear (as per instructions) the washers actually hit the next gear and make it so it wont turn. The washers are too big in diameter. We removed one washer and it now works fine. Andymark needs to step up their quality control!!
Unread 20-01-2015, 14:33
Monochron's Avatar
Engineering Mentor
I was wondering about that second washer, it makes it so that the CIM pinion gear doesn't mesh centered on the next gear. I was hesitant to remove a washer because the kit came with two . . . but if that could be causing my problem it would be an easy fix.
Unread 20-01-2015, 15:01
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
That was the exact same problem we had with 4 Toughbox Nanos we got for a summer project. We fixed them the same way.
Unread 20-01-2015, 15:09
Zyrano Zyrano is offline
AKA: Alvin
FRC #1967
Zyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to behold
Send a message via AIM to Zyrano
We had the same problem with the these gearboxes last year, you just need to play with the spacing of the gears relative to each shaft. We were able to use some hardware store nylon spacers to make everything work. if you look closely, you'll see that some of the gears are able to interfere with each other when you push the slop one way or the other. It was somewhat fustrating as my students had to assemble and disassemble multiple times before finding the problem.
W.R.R.F. Board member, 2007-??
Mentor, 2007-??, NDSJ Robotics FRC Team 1967
Mentor, 2013-15 Evasive Robotics FTC Team 6223
Supporter, 2006-11, Bulldogs Robotics FRC Team 581
Supporter, 2007-??, Pioneer HS Robotics FRC Team 668
Supporter, 2011-??, Dark Matter FRC Team 2643
Student, 1999- GRT FRC Team 192
Unread 20-01-2015, 21:49
Monochron's Avatar
Engineering Mentor
I removed a washer from each gearbox and the problem disappeared. I really have no idea why there are two there, unless one is intended to be a spare? When I called AndyMark asking about this the rep just said to run the gearbox for a while which would, I presume, just grind away at that gear/washer. Glad I didn't do that.
Yeah the middle gear cluster has at least 1/8" of slop to it. I'm not familiar with gearbox design, but I wouldn't think that is optimal, why not send another spacer in the kit? Either way they are working now for testing. We might consider adding some spacers that are on order, but it means removing and disassembling the gearbox.
Unread 22-01-2015, 14:02
oison75's Avatar
Bag of Water
FRC #0751
These were the aluminum gears that come with the Andy Mark gearbox. When it was all assembled, we tried manually spinning the shaft (with the CIM attached), and it kept jamming (meaning we couldn't turn it). We disassembled the gearbox and took a closer look at the gears: they were physically warped. Even laying them on a flat surface you could literally see gaps between certain areas of the gear and table. My guess is they were poorly manufactured. However, the steel gears were not warped, and did not jam.
