Go to Post So basically, the advantage of #35 is that it allows you to be sloppier in your design and fabrication. If you pay close attention to these details, you will never have a problem with #25 chain. - Jim Zondag [more]
Unread 19-01-2015, 16:59
Merfoo's Avatar
Merfoo Merfoo is offline
FRC #0955 (CV Robotics)
Merfoo is an unknown quantity at this point
Question Program LIDAR for PWM Java
We are trying to use the LIDAR sensor via PWM. How would we program this using Java? Right now we are trying to time the pulse length of the DigitalInput (would be PulseIn in Arduino), how would we accomplish this?
Unread 19-01-2015, 17:10
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: Program LIDAR for PWM Java
Can you link to a datasheet for the sensor?
Any post that I make expresses only my opinions. I do not represent the opinions of my team or of any entity affiliated with my team.
As a Mentor:
2016 - Engineering Inspiration at Greater Pittsburgh Regional
As a Driver:
2014 - Winner of Greater Pittsburgh Regional
Unread 19-01-2015, 17:17
Merfoo's Avatar
http://pulsedlight3d.net/assets.pl3d...ing-Manual.pdf
less in depth:
http://pulsedlight3d.net/assets.pl3d...Data-Sheet.pdf
Unread 20-01-2015, 12:34
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
Just so you know, there's an example code written by a ChiefDelphi user in Java (although it uses I2C).
https://gist.github.com/tech2077/c4ba2d344bdfcddd48d2
I wasn't able to find the equivalent function to pulseIn.
As a Mentor:
As a Driver:
Unread 21-01-2015, 11:53
The Semi-Period mode of the counter class should do this. http://wpilib.screenstepslive.com/s/...ulses-and-more
