Re: Fixing gearbox assembly inconsistancies
In the past, we've also had some issues with aluminum vs. steel gears. Aluminum gears tend to warp under pressure and get jammed, while steel gears don't. (Keep in mind this was with a 3-CIM Andy Mark gearbox and not the toughbox nano).
We've used aluminum gears extensively from VEXPro and ones we custom made...never seen one "warp under pressure and get jammed". It is highly likely you had another issue that was independent of the gear. For sure more information is needed before making a blanket statement that aluminum gears are worse than steel. |
Check to make sure your CIM mounting screws are not to long. That can cause The tuff box nano to not want to turn. Also check to make sure that the bearings did not get reversed.
We sent two back this year one for a gear that the bore was broached crooked, and the other was not the right width causing a lot of slop. The ones we got as replacement where fine but the included kit to mount the gear to the CIM with the two washers below the gear (as per instructions) the washers actually hit the next gear and make it so it wont turn. The washers are too big in diameter. We removed one washer and it now works fine. Andymark needs to step up their quality control!!
We had the same problem with the these gearboxes last year, you just need to play with the spacing of the gears relative to each shaft. We were able to use some hardware store nylon spacers to make everything work. if you look closely, you'll see that some of the gears are able to interfere with each other when you push the slop one way or the other. It was somewhat fustrating as my students had to assemble and disassemble multiple times before finding the problem.
#8
