Go to Post Drive fast...drive true...otherwise it will kind of crush you - techhelpbb [more]
Unread 18-01-2015, 15:59
Doug.Pateman Doug.Pateman is offline
FRC #4618
Doug.Pateman is an unknown quantity at this point
Programming Radio 2014 Config
We have our roboRIO up and running with code and responding properly through the USB connection.
Every time we run the FRC Bridge Configuration Utility it opens but the Network Interfaces box is just gray with no display and it just locks. I have uninstalled and reinstalled the software with always the same results.
We are using the utility dated 12/16/2014, and a FIRST Classmate.
Any ideas on what is wrong?
Unread 18-01-2015, 17:34
Re: Programming Radio 2014 Config
Is your ethernet port enabled and working?
Unread 18-01-2015, 19:28
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Try turning off the wireless adapter in the classmate. Also, I don't think this will help but you could try running the program as an administrator. Plug a single network cable straight into the bridge.
Brian K
Team 1225 Robotics Mentor
Unread 20-01-2015, 13:02
FRC #4618
These are both two good questions. I have got the system up and running as a home network and so we can work on the Bot but the program will not run. I forced things by hand.
We can upload code to the RoboRIO and "drive" both wired to the RIO with USB and wire to the modem with a CAT 5. Also we can do this wireless. So for development we have no issues.
My real concern is if there is something wrong with our classmate software as it sits and FIRST can't configure things for the competition at a regional we are stuck.
We have time to figure this out but I am stumped. The problem seems to be software related to me but maybe that is blinding me to the real problem.
Unread 20-01-2015, 13:25
Tungrus Tungrus is offline
Tungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the rough
Our classmate CPU goes 100% after driver station is loaded. Even when classmate is not connected to radio or roboRIO. There are no other softwares on this classmate. No antivirus no firewall. Windows 7 firewall is disabled and wireless is disabled.
Unread 20-01-2015, 16:05
If you CPU usage is 100%, you may try to kill the dashboard and see if that was the issue. Also, what happens once you connect to the robot? Can you characterize when this happens?
Greg McKaskle
