Go to Post I am mentored by individuals younger than 18 all the time. - Taylor [more]
Unread 20-01-2015, 12:11
Awesomegamer235 Awesomegamer235 is offline
None #4607
Awesomegamer235 is an unknown quantity at this point
help on coding camera
if i wanted to code a camera what vi's would i use
Unread 20-01-2015, 13:03
Re: help on coding camera
That depends greatly on what you want to do with the camera.
What do you want to do with the camera?
Unread 20-01-2015, 13:51
Infinit3PI Infinit3PI is offline
FRC #4607
Infinit3PI is an unknown quantity at this point
Having been looking at it, we are now attempting to integrate the example or a rendition of the example color and shape processor into the base RoboRIO vision processor.
We are working on getting a working autonomous period through vision recognition on the tote.
Unread 20-01-2015, 14:36
I think that the answer to "what vi's would i use to do what the example does" is basically "the ones the example uses to do what it does".
Where are you running into problems?
Unread 20-01-2015, 14:47
FRC #4607
Having looked a tad bit harder at the example code, I see where I was misleading myself. I didn't see how I was supposed to blend the two codes together, but it was simply an inability to see the obvious on my part.
