Go to Post We can help FIRST improve the system, but we can't just blame them and wait. - Siri [more]
Unread 20-01-2015, 15:09
Zyrano Zyrano is offline
AKA: Alvin
FRC #1967
Zyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to beholdZyrano is a splendid one to behold
Send a message via AIM to Zyrano
Re: Fixing gearbox assembly inconsistancies
We had the same problem with the these gearboxes last year, you just need to play with the spacing of the gears relative to each shaft. We were able to use some hardware store nylon spacers to make everything work. if you look closely, you'll see that some of the gears are able to interfere with each other when you push the slop one way or the other. It was somewhat fustrating as my students had to assemble and disassemble multiple times before finding the problem.
W.R.R.F. Board member, 2007-??
Mentor, 2007-??, NDSJ Robotics FRC Team 1967
Mentor, 2013-15 Evasive Robotics FTC Team 6223
Supporter, 2006-11, Bulldogs Robotics FRC Team 581
Supporter, 2007-??, Pioneer HS Robotics FRC Team 668
Supporter, 2011-??, Dark Matter FRC Team 2643
Student, 1999- GRT FRC Team 192
