Go to Post FIRST is the only sort of competition that I've seen where somebody can win and the opponents can be genuinely happy for them. - RiceRobotica [more]
Unread 17-01-2015, 15:32
Intern Intern is offline
FRC #3596
Intern is an unknown quantity at this point
Has anyone figured out limit switches for 2015
i do not know how to code limit switches in 2015 labview, can someone comment a picture and show me how to do it, i have it done in begin all i need is teleop
Unread 17-01-2015, 16:02
Re: Has anyone figured out limit switches for 2015
What do you want the limit switch to do? Describe exactly what you want the robot to do when the switch is open and when it is closed, and we can help you program it to do that.
Unread 17-01-2015, 16:13
FRC #3596
when the limit switch is pressed i want the cim motor to stop going that direction so it doesn't de-rail
Unread 17-01-2015, 16:35
That's a pretty typical use of a limit switch. Here's how I would do it, using an In Range and Coerce function. When the switch value is not true, the motor control is allowed to vary between -1 and +1. When the switch is true, the motor is only allowed to be between -1 and 0, keeping it from traveling any farther forward.
Name:	limit switch.png
Unread 18-01-2015, 13:40
andboyer andboyer is offline
FRC #4984
andboyer is an unknown quantity at this point
What motor controllers are you using? With the new controller you can connect the limit switch directly to the controller and it will function without any additional code. https://www.google.com/url?sa=t&sour...dAP2YN2BXa9lJQ
Unread 20-01-2015, 17:37
1uan 1uan is offline
AKA: Juan Halleran
FRC #2152 (S*M*A*S*H)
1uan is an unknown quantity at this point
How do you get the motor control dbl to show up
Unread 21-01-2015, 00:59
In my snippet, that was just a placeholder to represent the value you want to send to the motor. How you come up with that value is up to you. You can get it from a joystick axis, or select between different values based on joystick buttons, or compute it using PID based on sensor feedback, or anything you want.
Unread 21-01-2015, 09:54
AKA: Juan Halleran
thank you for the explanation
Unread 04-02-2015, 18:15
TheJuanRing's Avatar
TheJuanRing TheJuanRing is offline
FRC #1997
TheJuanRing is an unknown quantity at this point
hey this is kind of a followup, but has anyone figured out how to do it with c++???
Unread 04-02-2015, 19:18
ozrien's Avatar
ozrien ozrien is online now
Omar Zrien
AKA: Omar
This might help....the examples are in Java, but the class names are pretty similar.
http://wpilib.screenstepslive.com/s/...ommit=S earch
Unread 05-02-2015, 16:16
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
Here are some more examples in LabVIEW, both the limit switch tutorial and the state machine tutorial use a limit switch scenario.
Website of LabVIEW Tutorials for FRC
Unread 05-02-2015, 17:20
FRC #1997
thanks, both of you guys, for the examples, it is a huge amount better than what i had before
Edit: In hind sight I really should have thought about searching for that on the WPILib website
