Go to Post "There are two ways to compete in this world, you can drag your competitors down, or you can rise above them. Which is better for the world in the long run?" - Karthik [more]
Unread 20-01-2015, 18:59
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: Arm Issue
The first thing I would try is putting print statements in the initialize() method (or a breakpoint and debug it) to make sure it is being called when you think it is.
If that works, then check to make sure Robot.armOpenClose.armClose() is actually doing what you think it is.
