Go to Post The trick to designing is to identify the problem before finding a solution. - BJC [more]
Unread 20-01-2015, 19:01
Nickman4456 Nickman4456 is offline
FRC #4456 (Mech Cadets)
Nickman4456 is an unknown quantity at this point
Problem with relays
Recently I've been working on a circuit with a relay. I got the circuit to work, but then it broke. I think I've narrowed the problem to the relay, which is a DPDT (double pole double throw) relay. When the relay is magnetized, electricity doesn't seem to travel through the pole and the lead it's supposed to be touching when moved (due to the electromagnet pushing it away). Is this a common problem/ has it ever happened to any of you? Any suggestions to fix the problem? Thanks
Unread 20-01-2015, 21:45
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
Re: Problem with relays
More detail about what you are trying to do, and how you have things connected would be useful.
-Karlis
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
Unread 20-01-2015, 22:03
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
If you are using your own relay, and not a spike, be sure to put a diode across the coil in the opposite direction of the turn on current to clamp excessive voltage. without that, it could damage components which would lead to intermittent behavior.
Brian K
Team 1225 Robotics Mentor
Unread 20-01-2015, 23:51
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
Also, if you're using your own relay, it is considered a CUSTOM CIRCUIT so you can't run a motor off it.
From the manual
R44:
CUSTOM CIRCUITS shall not directly alter the power pathways between the ROBOT battery, PDP, motor controllers, relays,
motors, or other elements of the ROBOT control system (items explicitly mentioned in R55). Custom high impedance voltage
monitoring or low impedance current monitoring circuitry connected to the ROBOT’S electrical system is acceptable, if the
effect on the ROBOT outputs is inconsequential.
R41
The only power regulating devices for actuators permitted on the ROBOT include:
A: Motor controllers
B. Relay Modules
A. Spike H-Bridge Relay (P/N: 217-0220 and SPIKE-RELAY-H)
C: Pneumatics control module
I can't get the indentation right, but it says that the only relay that can be used to drive actuators is the purchased spike.
Unread 22-01-2015, 10:23
Couldn't the reverse-biased diode completely stop the relay from becoming magnetized (it's a low voltage relay)?
Unread 22-01-2015, 10:56
AKA: Karlis Musa
Since most/all of us are assuming that this is a DC relay that you are using, the diode isn't conducting when you energize the relay, so no.
The diode is there to dissipate the energy stored in the relay coil when you stop supplying power to the relay.
Unread 22-01-2015, 14:32
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
The relay output lines can only source 7.5 mA @ 5V. Make sure your relay meets that spec. As others have said, if it is not a spike it cannot control anything that moves.
Unread 22-01-2015, 23:35
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Can you post the part number for the relay? If it is an automotive type relay the common ones require 200ma to energize them. So with a supply that can only provide 7.5ma you'll never get a strong enough magnetic field to cause the relay to change state.
