Go to Post I'd just give you the URL, but then you wouldn't learn to look for yourself. - DonRotolo [more]
Unread 20-01-2015, 19:17
broswen broswen is offline
Programmer
FRC #4239 (Warpspeed)
broswen is an unknown quantity at this point
Mecanum drive cartesian problems
We are trying to use the mecanum drive cartesian method provided by wpilib. We are having a problem with the axis in the controllers not working properly.
We are using an xbox controller with 2 joysticks instead of a flight stick with a rotational axis. We are using the x and y axis on the left stick for the x and y variables called in the method and the x axis on the right stick for the rotation.
What is supposed to happen:
The left stick controls forward/backward and strafe left/right.
The right stick controls rotation.
The problem:
For example, when I push forward on the left stick the robot turns, and when I push left on the right stick it strafes.
When i push the left stick left/right the robot spins wheels but its not the right direction and doesnt move.
Has anyone successfully used the wpilib mecanum drive methods, and could you give us some tips?
We do not have a gyroscope set up currently and that variable is set as 0. Would that affect anything?
Unread 20-01-2015, 19:29
Dartmouth 2020
AKA: lopsided98
FRC #2084 (Robots by the C)
Re: Mecanum drive cartesian problems
I would check to make sure the motors are inverted correctly. Are you able to drive normally (arcade or tank)?
Unread 20-01-2015, 19:35
jtrv's Avatar
jtrv jtrv is offline
github.com/jhtervay
AKA: Justin
FRC #2791 (Shaker Robotics)
jtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to alljtrv is a name known to all
Sounds like your joystick axes are switched in the code. The rotation should be [-1,1], I'm not sure if positive goes clockwise since I don't have a drive base to test it with yet, but...
Cartesian is mostly used with gyro. I would recommend just trying polar for now, until you have a gyro set up.
With cartesian and gyro set to 0, the robot constantly thinks it has yet to rotate at all. So as a result, things might get wonky.
Unread 20-01-2015, 19:44
Dartmouth 2020
AKA: lopsided98
AFAIK, you should be able to use the cartesian methods without a gyro just fine. Internally the movement vector is just rotated by the gyro angle. Without a gyro, strafing will always be relative to the robot, so if you turn while strafing you will move in an arc.
Unread 20-01-2015, 19:54
Mecanum cartesian can be used without gyro. You don't need to use polar.
Put the bot up on blocks. Issue a pure forward command and note the direction each of the 4 wheels is spinning. Do the same for pure strafe right, and rotate clockwise.
Post your results here.
Unread 20-01-2015, 20:21
Programmer
We have fixed our robot, sort of.
We inverted one side of our robot and that fixed most of the problem.
The joysticks were opposite so we inverted those also.
now our robot works perfectly, except that our front is now our back and our back is our front. Other than that it is perfect. This is just a test chassis so direction isn't a problem.
Unread 20-01-2015, 20:51
Dartmouth 2020
AKA: lopsided98
That can be fixed with some more inversions. Before I cleaned it up, our mecanum code used to invert inputs three or four times before they finally reached the motors.
Unread 20-01-2015, 21:58
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Did you verify that the wheels are installed in the correct orientation? Rollers on diagonal wheels should point in the same direction, with opposite directions on each diagonal.
Brian K
Team 1225 Robotics Mentor
Unread 20-01-2015, 22:42
That's necessary, but not sufficient.
X when viewed from top.
Unread 22-01-2015, 01:14
jwalker0 jwalker0 is offline
FRC #3673
jwalker0 is an unknown quantity at this point
If it's moving opposite to what you expect after inverting the motors on one side, then you inverted the wrong side. We needed to invert the right-side motors to get ours working properly.
Unread 06-02-2015, 08:33
jls667 jls667 is offline
None #2579
jls667 is an unknown quantity at this point
Could someone post code for using mecanum wheels and a gyro? I have the mecanum wheels working great without the gyro. I am using Java.
Unread 06-02-2015, 08:59
Programmer
We haven't used mecanum wheels with a gyroscope at all. I would guess you have to create a gyroscope in the code and add it to the mecanum drive function.
Unread 06-02-2015, 09:12
You have to tell us what you want to use the gyro for. For field-oriented control? To correct minor drift when trying to drive straight? Both? Neither?
Unread 06-02-2015, 10:26
None #2579
I would like to set up field-oriented control.
Unread 06-02-2015, 10:33
Are you using home-brew mec code, or WPILib robotdrive.java?
If the latter, mec cartesian has an input parameter for gyro. That gives you field-oriented control.
If the former, just grab the rotateVector code from WPIlib.
