Go to Post Every year, everyone reads too much into the hints given by Dave. - EricH [more]
Unread 20-01-2015, 20:09
Jpatterson1710's Avatar
Jpatterson1710 Jpatterson1710 is offline
AKA: Josh Patterson
FRC #1710 (Ravonics Revolution)
Jpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura aboutJpatterson1710 has a spectacular aura about
AndyMark C-Channel
Does anyone know of a replacement option for the AndyMark 72in C-Channel, Part # am-3052? They are out of stock, and we really need some.
2012-2014 Mechanical Team FRC 1710
2014-2015 Chief Operations Officer FRC 1710
2016-Present FTAA
Unread 20-01-2015, 20:17
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: AndyMark C-Channel
Do you need all the holes in the c-channel?
Vexpro has a similar product at 59"
http://www.vexrobotics.com/vexpro/versaframe/versaframestock.html
If you do not need the holes at all you can pick up 4 or 8 ft sections from mcmastercarr
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 20-01-2015, 20:41
AKA: Josh Patterson
Yeah, I saw those. I think we'll have to hold out for the AndyMark stuff. Thanks for the quick reply.
2016-Present FTAA
Unread 20-01-2015, 20:45
Imaginary Friend
AKA: Kevin Li
Team Role: Student
What about this?
http://www.vexrobotics.com/vexpro/ve...pro-frame.html
Kevin Li
596 - Sciclones
Unread 20-01-2015, 21:31
AKA: Josh Patterson
The issue is that we already have systems with the AndyMark stuff, which is not exactly 1 inch. It seems sort of "Craptastic" to make the, now, more preferable Vex stuff to fit. If it seems like it will take a while to get back in stock, we'll probably just go with it, and we can make it work. Again, thanks for the ideas!
2016-Present FTAA
Unread 20-01-2015, 21:44
Mike Marandola Mike Marandola is online now
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
It's more expensive but they have a 30" length in stock.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 20-01-2015, 23:14
AKA: Josh Patterson
Check out the side holes, 30in pieces have pre-drilled holes for drive bases. 72in pieces have a one inch pattern. It looks like its time to give in and get the Vex. Thanks everyone.
2016-Present FTAA
Unread 21-01-2015, 08:02
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
That part is for the old c-base chassis so they may not be making it anymore, there is no re-stock date. I would call AndyMark and see if they are planning on getting more in stock or you may be waiting a while.
Unread 21-01-2015, 08:55
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
This part was a new product in the off season so I would hope it isn't discontinued.
Also they do note the product is different than the 30" pieces.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 21-01-2015, 09:03
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
We made the switch to VEX this year (including the new clamp on gearbox). Just a warning that it is not so easy to mix and match the chassis parts.
The VEX C-Channel is 1" OD and the AM is 1" ID (1.25" OD), which means the Vex will slide into the AM (good) but you can not use the extruded corner connectors from AM on the VEX (bad). The VEX system assumes external gussets (with rivets) to constrain the corners.
Unread 21-01-2015, 18:48
AKA: Josh Patterson
For anyone who may be wondering - An AndyMark rep told me that they will likely have 72in back in stock by the end of this week, or end of next.
2016-Present FTAA
Unread 23-01-2015, 19:08
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
You could also check onlinemetals.com....
Aluminum Channel Link:
http://www.onlinemetals.com/merchant...p=2&top_cat=60
They have *everything* metal.....
