Go to Post Some said the aluminum foil gave the robot a NASA-like quality, but others pointed out that blanketing components with a highly-conductive material that blocked air flow was probably not going to help get us to Einstein. - beerobber [more]
Unread 20-01-2015, 20:06
FrankenmuthK's Avatar
FrankenmuthK FrankenmuthK is offline
FRC #5215
FrankenmuthK is an unknown quantity at this point
360 HELP!!
Need help understanding how to use a xbox 360 controller for the robot instead of a regular joystick. Like coding and reference names for the controller
Unread 20-01-2015, 20:22
forbes's Avatar
forbes forbes is offline
Software developer
AKA: Evan Forbes
FRC #3507 (Ubotics), 694 (StuyPulse)
forbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to beholdforbes is a splendid one to behold
Re: 360 HELP!!
It works essentially the same as a joystick.
If you plug the controller into the driver station computer, open the "FRC Driver Station" program, click on the USB devices tab on the left, and select the controller in the list- you will be able to see the mapping of axes and buttons (starting from 0), and whatever the number left of the controller is in the list will be the number of that "Joystick" in Begin.vi.
Unread 20-01-2015, 21:13
FRC #5215
Re: 360 HELP!!
Do you have any tips for a new programmer like myself?
Unread 20-01-2015, 23:42
forbes's Avatar
Software developer
AKA: Evan Forbes
Re: 360 HELP!!
I recommend looking at the examples in LabVIEW -> Help -> Find Examples...
They have code for almost everything a team would want.
Unread 22-01-2015, 16:37
FRC #5215
Re: 360 HELP!!
Does anyone have a screen shot of what the POV should look like on Labview?
Unread 23-01-2015, 08:15
Maximillian's Avatar
Maximillian Maximillian is offline
AKA: Max Westwater
FRC #5254 (HYPE)
Maximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant futureMaximillian has a brilliant future
Re: 360 HELP!!
Here is the axis, button and POV mapping for an Xbox 360 controller.
