Go to Post "Well, geez, I can't figure this out. I cut the piece [I]three times[/I] and it's still too short!" - joshsmithers [more]
Unread 20-01-2015, 14:05
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
How is possession determined in regards to resources open to both sides?
Not seeing a rule that dictates what happens when two robots are at a recycling bin and are attempting to grab onto it. Is it first come first serve? Tug o War? Rock, paper, Scissors?
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
So I got my jacket back, but it turns out the "W" in WPI doesn't stand for that steak sauce I can't pronounce.
Play is for kids this is serious...
Unread 20-01-2015, 14:07
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Mine...
I would suggest changing the name of the thread to be more detailed.
Unread 20-01-2015, 14:14
Re: Mine...
That better I feel like now its too complex but the question still stands.
Two robots roll up to a tote on the step at the same time, how is it determined which side gets it?
I mean if I'm touching it first is the rule why not just make a robot that barely touches all totes on the step is well within the frame constraints (or lack there of).
Unread 20-01-2015, 14:42
Re: How is possession determined in regards to resources open to both sides?
I don't see a rule that grants possession to a robot based on anything other than its ability to take possession.
Unread 20-01-2015, 14:44
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
I'm envisioning it'll be like a football scrum. As long as any skullduggery isn't obvious, let the strongest robot win!
Hi!
Unread 20-01-2015, 14:45
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Mine...
In 2010 & 2011 it was determined by the robots on the field. A bot could literally steal the tube or soccer ball from the opponent's roller claw and get away with it, even after the tube was in the air. It caused many a deflated tube in 2011.
Another question is what happens if both go after a RC, both grip but slip out, causing the RC to fall on one of the sides. Is a penalty assessed, and to whom?
Unread 20-01-2015, 15:53
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
Re: Mine...
I've been mulling basically the same thing....
We have a decent drive train and a pretty strong "grabbing" device... I could picture us grabbing a recycling bin off the step at about the same time (or just after?) a rather top-heavy robot on the other side and dragging both the recycling bin and the other robot over... Would we be penalized for this? Would they?
Unread 20-01-2015, 16:32
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I think this will largely be in the judgement of the referees. In 2013 (insert the usual caveat about applying different years rules.) robots were penalized for "tripping" robots with high center of gravity. So if it seen that your robot & drivers actively pulling another robot over even if you were primarily going after a game piece, I would expect you to get penalize. But I have consistently proven I cannot predict the GDC or the referees.
Unread 20-01-2015, 17:44
Here is how Q&A answered a very similar question:
Q29 Q. If the actions of one alliance cause the other to violate G18, which alliance will be penalized? For example, if one robot from each alliance has a grasp on a container on the step and the blue alliance robot is pulled over the step by the red alliance robot while pulling on the container.
A. We can't answer your question as there are many different scenarios that could be in play. If the violation is momentary (i.e. the ROBOT is only momentarily in contact with that RECYCLING CONTAINER that is now on the opposite side of the STEP, but lets go quickly and retreats), then there's no violation and neither ALLIANCE is penalized. If, however, the contact is extended, the ALLIANCE with the ROBOT violating G18 will be penalized.
I'm not sure if I have a clear answer....
Unread 20-01-2015, 20:15
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Originally Posted by Q&A
Q29 ... If, however, the contact is extended, the ALLIANCE with the ROBOT violating G18 will be penalized.
As I read this, you should not get into a tug of war across the step unless you are confident you will win.
Richard Wallace
since 2003
Unread 20-01-2015, 21:07
magnets's Avatar
magnets magnets is offline
However, if you are confident that you will lose so badly that your robot will get pulled to the other side of the field, you may want to consider playing defense while you're over there
Unread 20-01-2015, 21:49
kmusa kmusa is offline
AKA: Karlis Musa
FRC #0639 (Code Red Robotics)
kmusa is just really nicekmusa is just really nicekmusa is just really nicekmusa is just really nice
or at least know when to let go.
"A society without contrasting ideas will never move forward; however those contrasting ideas must be based on fact, must be rational/logical, and must be presented in a respectful manner." -Arthur Dutra IV
"If the district can spend $1.5M on turf, it should be able to fund a FRC team." -Sophie Halter
Unread 21-01-2015, 16:21
Q. How far does an object (tote or recycle bin) have to be off of the Step so that the other alliance would be penalized under G18 for touching it? For example a recycle bin tipped on its side half resting on a tote and half resting on the step?
2015-01-21 by FRC0364
A. Imagine a plane extending upwards from the far edge of the STEP, if a ROBOT part crosses through that plane, it can't touch anything on the other side per G18. So if any portion of the object is still on the near side of the plane, the ROBOT could touch that portion.
Seems straightforward. Whoever wins the tug of war gets the object regardless of who was in possession first.
This does however mean if you designed a hook that hooks onto a tote or bin then that connection better be stronger then the guy on the other side otherwise you will have your debris crossing over to the other side of the step and that is not a pretty penalty...
Unread 22-01-2015, 15:06
rpaulsen rpaulsen is offline
Mr. Paulsen - Huguebots Coach 5202
AKA: Mr. Paulsen
FRC #5202 (The New Ro Bots)
rpaulsen is an unknown quantity at this point
Unless I am missing something in the rules, I don't quite understand why this would be issue. Within the context of a game there is little reason for any two robots to fight over who gets possession of a tote.
In the case of two alliance members fighting over a tote, this just seems self defeating for both teams, as their cumulative score is the score they will record for the match. At such, fighting over possession of a TOTE simply wastes time where one of the teams could be grabbing another TOTE to increase both teams scores.
There are only two instances where I could see this coming into play with the opposing alliance. First is with Coopertion stacks, but once again it is self defeating for the two alliances to fight over who gets to complete the stack because all 6 teams get the same amount of points. It would be far more productive for all teams involved to figure out which robot will deliver the gold TOTES to the STEP, and then also decide which one of the 6 teams will complete the stack once it is on the STEP.
The second instance is in regards to the 12 grey TOTES that start the match on the step. I guess if both teams can clear all the TOTES from the LAND FILL required to reach the TOTES on the STEP, and go for these 12 TOTES at the same time this could be an issue. But that seems like a lot of work for both teams to complete in 2 minutes, when there are so many more TOTES readily available.
Unread 22-01-2015, 15:14
Jared's Avatar
Jared Jared is offline
Most people in this discussion are talking about the 4 green recycling containers in the center of the field. They can be worth huge points to an alliance, and it's not unreasonable to expect some teams to go after these in autonomous mode when they are unable to stop and control their robots.
