Go to Post Also, after 3 years of FRC I finally hugged that Platypi! - That 281 Guy [more]
Unread 05-01-2015, 01:07
ejb1123 ejb1123 is offline
AKA: E.J. Bevenour
FRC #5404 (Gearaffes)
ejb1123 is an unknown quantity at this point
C++ dashboard
In the driver station for the FRC 2015. There is a option for C++ dashboard. I have read that the c++ was for wind river devkit, but with the transition to eclipse for c++ I don't know how I would make a dashboard in C++. How would this be done?
It might be useful for client side(DS Computer) image analysis with openCV instead of compiling it to run on the roborio.
Unread 05-01-2015, 09:51
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Re: C++ dashboard
For C++ and Java, we support easy sending of data to the SmartDashboard via NetworkTables. You can find information about how use the SmartDashboard here: http://wpilib.screenstepslive.com/s/...-robot-program. Note that while many of the examples are in Java, the same functions are available in the SmartDashboard class in C++. So where Java has
SmartDashboard.putString("name", "value");
C++ would have
SmartDashboard:: PutString("name", "value");
Last edited by fsilberberg : 05-01-2015 at 09:52. Reason: Put code blocks around the code sections
Unread 05-01-2015, 10:29
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
Re: C++ dashboard
Although the code is written in Java, the white paper here: (http://www.chiefdelphi.com/media/papers/2676) is an excellent resource for doing vision processing off-board on the laptop. This code was used by 341 for the past 3 years and it gets the image from the axis camera on robot, and then goes through a series of filters, compressions and other processes and finally displays the image to the Smart Dashboard.
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
Unread 05-01-2015, 11:22
Re: C++ dashboard
To clarify, the C++ Dashboard option on the Driver Station will launch the SmartDashboard, which you can interact with using the code in Fred's post. This option was there in previous years also. You can read more about SmartDashboard here: https://wpilib.screenstepslive.com/s/4485/m/26401
You can also write your own dashboard in any language you want, and have it launched by the Driver Station by modifying the ini file referenced here: https://wpilib.screenstepslive.com/s...tware#SetupTab
Unread 17-01-2015, 13:21
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Re: C++ dashboard
The link for how to set DS.INI to run the smart dashboard points to an invalid page? What is the syntax in ds.ini to start the smart dashboard?
Brian K
Team 1225 Robotics Mentor
Unread 17-01-2015, 21:46
Re: C++ dashboard
In FRC DS Data Storage.ini, change the line
DashboardCmdLine = ""C:\\Program Files (x86)\\FRC Dashboard\\Dashboard.exe""
to point to another file built in C++. The doubled characters are so that the ini file will treat them like a path that contains spaces.
Greg McKaskle
Unread 17-01-2015, 22:59
SuperBK's Avatar
AKA: BrianK
Re: C++ dashboard
Should this work to start the smart dashboard automatically when I select "Default Dashboard":
DashboardCmdLine=""java -jar C:\\Users\Developer\\wpilib\\tools\\SmartDashboard .jar""
Also even if I set the driver station to "C++ Dashboard", it defaults to "Labview" the next time I run it.
Brian K
Unread 18-01-2015, 07:28
Re: C++ dashboard
The ini setting you show looks like it would work. Please put it into a cmd window, without the duplication of \ and ", and see if it works there. That is pretty much all the DS does with it.
As for the second issue, yeah. The refactoring accidentally turned the Default DB into a Boolean, which turns into a 0 or 1, which means the only two settings that persist the round trip are Default and LV. Sorry bout that. We are, of course, hoping that no update will be needed, but there are a few smaller issues like this that will be fixed if/when there is. I understand that there is a known issues list, but I couldn't find it just now.
Greg McKaskle
Unread 18-01-2015, 10:57
SuperBK's Avatar
AKA: BrianK
Re: C++ dashboard
I had one single backslash in there, but still no joy. It just starts the default dashboard. I tried it on two different computers. For now, we will just have to start it manually.
Thanks,
Brian
Brian K
Unread 18-01-2015, 16:50
althebaker43 althebaker43 is offline
FRC #2135
althebaker43 is an unknown quantity at this point
Re: C++ dashboard
I was able to start the SmartDashboard JAR by specifying the absolute path to the JRE executable, like so:
DashboardCmdLine = "C:\\Program Files\\Java\\jre1.8.0_25\\bin\\java.exe -jar C:\\Users\\althebaker43\\wpilib\\tools\\SmartDashboard.jar"
Unread 18-01-2015, 19:22
SuperBK's Avatar
AKA: BrianK
Re: C++ dashboard
Sorry, didn't work for me. java was already in the PATH. Interestingly, it pointed to c:\ProgramData\Oracle\java\javapath. I didn't know java was there and I had installed it again under "Program Files". I changed my path to that, but still get the default dashboard.
Brian K
Unread 18-01-2015, 21:16
Re: C++ dashboard
If /when the java dashboard selector worked, it would have sent
java -jar C:\Users\UserName\wpilib\tools\SmartDashboard.jar
to the a default shell.
If you cannot get the ini file to work, you can put a Dashboard.exe where the FRC Dashboard is installed. But I don't really see why the CmdLine doesn't work.
Greg McKaskle
Unread 18-01-2015, 23:09
SuperBK's Avatar
AKA: BrianK
Re: C++ dashboard
I replaced Dashboard.exe with one of my own that executes
java -jar C:\Users\developer\wpilib\tools\SmartDashboard.jar
and it works to load the smart dashboard. I saved a copy of the default dashboard of course.
Not sure why the command line didn't work either, but enough fooling around this this for now. if anyone wants a copy of it, let me know.
Thanks for all the suggestions,
Brian
Brian K
Unread 20-01-2015, 22:21
SuperBK's Avatar
AKA: BrianK
Re: C++ dashboard
I found the correct page (by reading Chief Delphi)
https://wpilib.screenstepslive.com/s...anual-id=24192
The file I should have been editing is
C:\Users\Public\Documents\FRC\FRC DS Data Storage.ini
and NOT
DriverStation.ini in the driver station folder.
No wonder it didn't work!
Brian K
Unread 21-01-2015, 08:24
Re: C++ dashboard
Whew. So not a bug. Thanks for letting us know.
Greg McKaskle
