Go to Post 15 thread derailment points - EmileH [more]
Unread 21-01-2015, 07:26
Gabriel Mendes Gabriel Mendes is offline
FRC #1382
Gabriel Mendes is an unknown quantity at this point
Problem With Limit Switch
Hi everyone, I am having trouble programming a limit switch in labview that when it activates a LED indicator would blink in the front panel, but whenever someone presses it the LED would just stay active or it wouldn't activate at. Does someone know whats wrong with my program?
<--------------Begin-----------><---------------------Teleop-------------->
Open->DigitalInputRefNum set->DigitalInputRefNumget->DigitalInputGetValue->BooleanIndicator(LED)
Thanks, Go Team #1382
Unread 21-01-2015, 07:43
Re: Problem With Limit Switch
How do you have the switch wired? It should connect between the "ground" and "signal" pins of a Digital Input on the roboRIO.
Your paraphrase of the program looks okay. We can't tell whether the program itself is correct.
Unread 21-01-2015, 08:06
FRC #1382
Thanks Alan it was the wiring, now the program is working properly
Unread 21-01-2015, 08:43
Tungrus Tungrus is offline
Tungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the roughTungrus is a jewel in the rough
Reminder for those using limit switch, do not use 2 pin connector for DIO pins to connect to ground and 5V, its essentially shorting the 5V. Use 3 pin PWM connector and remove the center pin or disconnect the center wire (typically red).
Please correct me if I am wrong.
Unread 21-01-2015, 14:02
philso philso is offline
FRC #2587
Make sure you are not using the limit switch as the end stop for your mechanism. They often break when you do that.
Unread 21-01-2015, 22:57
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Correct. You want the load to engage the limit switch as it goes past, not as it slams into the switch.
Unread 22-01-2015, 10:31
Some teams extend the switch lever with a piece of small flexible tubing. That way the load simply bends the tubing and does not crush the lever.
