Go to Post It's a game feature, they're helping us, please don't complain too loudly.... - MrForbes [more]
Unread 20-01-2015, 14:08
michaelwm's Avatar
michaelwm michaelwm is offline
Integrated Systems Lead
AKA: Michael Midura
FRC #4976 (Rebel Robotics)
michaelwm is a jewel in the roughmichaelwm is a jewel in the roughmichaelwm is a jewel in the roughmichaelwm is a jewel in the rough
nashorn Script Engine NullPointerException
Hello! Our team is trying to use Java 8s new nashorn engine on the new roboRIO, as it runs Java 8. However, we have encountered a NullPointerException every time we call new ScriptEngineManager().getEngineByName("nashorn"). After a little debugging, we know it is the method getEngineByName that is returning null. We have tried rhino, simply getting every javascript engine, but we keep getting returned null. Is this a problem with the fact the roboRIO is running an embedded version of Java 8? Can another team try this?
Integrated Systems
Unread 20-01-2015, 15:44
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Re: nashorn Script Engine NullPointerException
Correct. You can take a look at the API's included in our profile for the JRE here: http://www.oracle.com/technetwork/ja...w-2157132.html. We use the compact 2 profile when creating the JRE. If you need to use Nashorn, you can create your own JRE and install it in /usr/local/frc/JRE. Take a look here for stuff about creating custom JREs: http://docs.oracle.com/javase/8/embe...e.htm#A1161602. We use the following options when running JRECreate:
private static String[] JRE_CREATE_COMMAND = {"java",
            "-jar",
            "", // This is the JRECreate jar location
            "--dest", "JRE", // This is the folder that you need to put in /usr/local/frc
            "--profile", "compact2",
            "--vm", "client",
            "--keep-debug-info",
            "--debug"
Unread 20-01-2015, 22:02
Qormix Qormix is offline
Programming Captain
AKA: Marc Levesque
Qormix is an unknown quantity at this point
Re: fsilberberg
Thanks for the documentation I was able to create a jre haven't tested it on the RoboRio yet.
I have another question. Is this legal for competition? I don't want to ruin the spirit of FIRST
hears what I added
            "-jar",
            "--vm", "client",
            "--debug"
            "--extension", "nashorn"
Team 4976
Marc Levesque - Programmer
Unread 20-01-2015, 22:10
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: fsilberberg
I have another question. Is this legal for competition? I don't want to ruin the spearit of FIRST
hears what I added
            "-jar",
            "--vm", "client",
            "--debug"
"spearit"....
This should be totally legal for FIRST. The Linux kernel on the roboRIO is simply an interface to the FPGA, the important stuff (sending PWM signals, etc) is done outside of the power of the kernel.
The spirit* of FIRST is to inspire technology, learning how to embed java runtimes on linux kernels is certainly inspiring
Unread 21-01-2015, 08:20
WPILib Developer
FRC #0190
Re: fsilberberg
hears what I added
            "-jar",
            "--vm", "client",
            "--debug"
As far as I am aware, it should be legal. One thing you'll need to be careful of, though, is memory usage. One problem we had when we first started experimenting with java (this was before java 8 was out) was that the jvm used too much memory and crashed on startup. I'm not saying that it will for you, and we haven't seen this issue since we upgraded to java 8, just be aware of it.
