Go to Post Analyze, adjust, anticipate. Don't panic. - PayneTrain [more]
Unread 20-01-2015, 22:44
apm4242 apm4242 is offline
FRC #4242
apm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud of
pic: 4242 Preliminary CAD 2
Unread 20-01-2015, 22:45
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
Re: pic: 4242 Preliminary CAD 2
Have you put into consideration of the CoG? That's what our team is having issues with right now.
Within the CAD Program's features, we tested the CoG of our original design and found 2 totes would make it tip over and have a catastrophic failure. Since then we have revised the design.
College sux yo
Unread 21-01-2015, 00:42
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Yeah, we quickly found out that that design does create some interesting CoG problems as well. I urge you to investigate it now while you still have time to fix it.
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 21-01-2015, 07:46
FRC #4242
Did you have CoG problems after weighing down the back end or before? The plan is to put around 25lbs back there.
Unread 21-01-2015, 09:19
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Keep in mind that the battery is ~13lb. That is a free counter balance if you locate it correctly.
Unread 21-01-2015, 09:40
Chris is me's Avatar
AKA: Pinecone
It is possible to build a design like this and offset your COG somewhat if you are deliberate about putting all of your extra weight in the back.
My concern would be about the elevator twisting. If I was using the REV extrusion or 80-20, I would consider something like Team Indiana's elevator which used four posts instead of two for more support.
Unread 21-01-2015, 10:36
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Originally Posted by gpetilli View Post
Keep in mind that the battery is ~13lb. That is a free counter balance if you locate it correctly safely.
Fixed that for you.
Unread 21-01-2015, 12:38
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
you could also move your lifting posts behind your front wheel to help with CoG.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 21-01-2015, 13:38
philso philso is offline
FRC #2587
Please ensure that your design and your manufacturing methods allow you to adjust the spacing of the vertical rails so that they are locked at the correct spacing for the lift carriage and so that the vertical rails are the same distance apart at the top and the bottom. Otherwise, your lift carriage will not move smoothly or may jam at one end of the travel.
You may also want to consider the various height limitations, direct and indirect, especially if your team intends to do well.
Unread 21-01-2015, 15:06
FRC #4242
Good insight, philso. We were going to tap the ends of the uprights and fasten them to the top piece but we may go with angle brackets now for adjustability. We also plan on putting a crossmember on the angled supports for rigidity.
You're right. we're trying not to bite off more than we can chew. I'd much rather a more limited design that does one or two things consistently.
Thanks
Unread 21-01-2015, 20:34
FRC #2587
It is not clear how tall your robot is. My comment about the height limitations is a reference to the direct height limitation (see R3 in the Game Manual) which is obvious and one that is not so obvious (see http://www.usfirst.org/sites/default...nstruction.pdf). It would be sad to see a team have to take a hacksaw to their robot before bagging it after winning at a regional. The height limits have been discussed in some other threads here on CD.
