Go to Post Brains and hard work aren't necessarily about age or grade. - Redhead Jokes [more]
Unread 21-01-2015, 11:04
Jtbillick Jtbillick is offline
FRC #4780
Jtbillick is an unknown quantity at this point
RoboRio imaging issues
Hey, I'm a programmer from team 4780 and I've been trying to image the roboRio. I have updated the firmware. Everytime I try to image the roboRio I get this error and the format targets don't show up. Does anyone know how I can fix This?Click image for larger version
Unread 21-01-2015, 11:24
Re: RoboRio imaging issues
Did you move the imaging tool from its default location?
Unread 21-01-2015, 11:29
FRC #4780
Yeah I did. Would that cause an issue?
Unread 21-01-2015, 11:32
You seem to be running the roboRIO Imaging Tool from your desktop.
So the roboRIO Imaging tool seems to be looking in the wrong filename path for the FRC Images, because it looks for a local folder called FRC Images.
Copy the roboRIO Imaging Tool back to:
C -> Program Files -> National Instruments ->LabVIEW 2014 -> project -> roboRIO Tool
and try running it from there.
P.S. too late, already answered..
Unread 21-01-2015, 11:33
The error message suggests that it is looking for the image files in a folder relative to the location of the program. If you moved the program but didn't also move the folder containing the images, that could be a problem. Put it back where it wants to be.
Unread 21-01-2015, 15:20
FRC #4780
Thanks so much. The issue is fixed
