Re: actuating a brake or anti-backdrive
I don't know what your gearbox ratio is to do your lifting or how much you wan't to lift but I would strongly suggest looking at your motors used, gear ratios, and power consumption to see if you can hold is strictly with programming which would be stalling the motor. For something like a cim, it wouldn't be as big of a deal to stall under the right loads compared to something like a 550 or 775 that relies on the turning of the shaft to cool it. There are some pretty good papers on Chief already talking about thermal mass and such. -Ronnie |
In addition to worm drive boxes, there are some drill gearboxes that have locking chucks which essentially prevent backdriving. The most popular one is the Dewalt XRP and there is a cheaper one from Harbor Freight.
It may just be simpler to use a transmission which cannot backdrive, like a worm gear. They provide large amounts of reduction in a small amount of space, and do reasonably well with large amount of torque. We plan on using a 10:1 worm reduction in our elevator for exactly these reasons.
If you'd like more details on the worm drive we're using, let me know and I can send you some specifics. |
Provided your torque requirements aren't too high, and you're using a motor which can handle it, you can implement a brake in software. Short version, you can use a PID to maintain the position of the motor using a holding current. We've done this before using CIMs and Bag motors. This does require a sensor.
. Although that might explain why the robot does not drive as fast as we would like ![]() |
#7
Scenario: Because of friction in the system, any force between 20 and 30 pounds will hold the load stationary once it's not moving. If your control algorithm is clever enough, it will use as close to 20 pounds as possible to hold the load. |
#8
Where is that 20-30lb estimate from? We need a brake on ours, and it would be nice if we could just hold that little amount of weight.
#9
It's not an estimate. It's just a scenario to illustrate a concept.
Or were you asking why there's a range, rather than just a single number? |
#10
I'm drawing a blank...probably because I can't see what it is we're trying to figure out how to stop moving. Can you post some pictures or drawings or renderings of the robot or design?
#11
Just a warning that the window motor also has a pin that engages when not energized that causes issues with speed controllers - there are CD threads on how to remove the pin. Also keep in mind that the ratcheted gearboxes from last year can not drive in both directions - by design. Depending on how you unload your elevator, you may need to drive the motor backwards. We chose the RAW drive due to its simplicity to control. The PID loop does not have to do anything special (like engage a break) and can drive to a desired position in either direction. Given the relatively large load of up to 60lb, we were concerned with the holding current for traditional gearboxes. AndyMark shows the RAW box as out of stock, and has removed the estimated restock time of Jan 26th. We did not want to wait till Jan 26th and ordered the individual part to build our own - which turn out to be more difficult than imagined. They do seem to have restocked the "worm box" and perhaps it is sturdy enough for your elevator. Other wise, your best bet may be the tailgate motor if you want a worm drive. |
#13
It's a pneumatic cylinder. You can see it in the video near the disk brake.
