Go to Post Hearing about the beginnings of 842 was truly inspirational and has really stuck with me through the years. After following you guys for so long it was crazy for me to play with you. Thank you for all that you have done for FIRST in Arizona. - Saberbot [more]
  #46   Spotlight this post!
Unread 21-01-2015, 00:55
Jared Russell's Avatar
Taking a year (mostly) off
Re: Is Autonomous worth it?
I think there will be events where the autonomous high score is 12.
I think there will be events where the mean autonomous score is below 4.
I think there will be events where the mode autonomous score is 0.
Last edited by Jared Russell : 21-01-2015 at 16:49. Reason: Meant mean rather than median
  #47   Spotlight this post!
Unread 21-01-2015, 07:21
pfreivald's Avatar
AKA: Patrick Freivald
I think there will be events where the median autonomous score is below 4.
I think you're probably right.
As to "the math," it's very, very easy: you have fifteen seconds in which to score points. Is it better to score points *and* set yourself up for teleop, score points only, set yourself up for teleop only, or do something else?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #48   Spotlight this post!
Unread 21-01-2015, 07:34
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
The question this year isn't "is it worth it to do autonomous?" - it's "do we want to be the only ones that don't do autonomous?"
Hi!
  #49   Spotlight this post!
Unread 21-01-2015, 12:00
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
And if you have a robot that can sore 20 in autonomous every time - single-handedly - or *cough* 28, would it not be worth doing - while your two alliance partners start preparing to stack?
More than the last several years, when thinking about Autonomous this year, we have to think of ourselves not as a single robot but, rather, as a member of an alliance. Yes, the center recycling containers will be important - especially in tougher events/matches. However, only one or two robots needs to make a move for them. Yes, stacking the recycling bins that start on our side is important - but how many robots need to do that at once. Up to 32 autonomous points are possible - that's too many points to completely ignore - especially when you can compile them before sending a single tote out of the feeder station.
The key will be coordinating the efforts of the entire alliance... Robots able to do a couple of different things (even/especially? during autonomous) will have an advantage as they will find success with different mixes of alliance members.
  #50   Spotlight this post!
Unread 21-01-2015, 12:07
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
The question isn't "should we", it's "what should we". There are a lot of ways to spend your time, and some of them might result in more than 20 or 30 points later in the match. Of course, most of us know that by now. I just think the "points" in auto might be forgone by a number of teams.
  #51   Spotlight this post!
Unread 21-01-2015, 12:14
Taylor's Avatar
AKA: @taylorstem
Agreed. But if your alliance doesn't get an autonomous score because your robot didn't move - regardless of the outcome of the match - that could be damaging to your team's image.
Hi!
  #52   Spotlight this post!
Unread 21-01-2015, 12:26
mrnoble's Avatar
teacher/coach
Right, of course. I hope every robot moves. (could this be a reasonable hope this year?)
  #53   Spotlight this post!
Unread 21-01-2015, 12:48
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
I don't remember any robots not moving last year by the end of the regionals. Mind you, we did see issues with robots moving the wrong direction or not stopping and slamming into the wall.
  #54   Spotlight this post!
Unread 21-01-2015, 12:57
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
My question is did some team dare to make a robot that didn't move and do they have a super strategy....
It would be a risky move but who knows I find this community of students and mentors is very very smart and creative.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
So I got my jacket back, but it turns out the "W" in WPI doesn't stand for that steak sauce I can't pronounce.
Play is for kids this is serious...
  #55   Spotlight this post!
Unread 21-01-2015, 14:34
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Autonomous is always worth it, and if it wasn't possible first wouldnt make it sound possible, our design this year is going to specifically focus on stacking three in auto and bringing them into the autozone in the allotted time, aswell as another auto the grabs two recycle bins off the step( at the same time), since we could do this we could do everything else the game calls for aswell. therfore in my opinion i think it is highly vALUBALE!
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
  #56   Spotlight this post!
Unread 21-01-2015, 14:39
who716's Avatar
HAHA we tetered on the thought of a stationary elevator system that would go from the human player station to the near platform that would raise and lower by air cylanders therfore the human player would just place the tote out of the chute and it would travel on up the elevator then come off at the platform the we would raise it too the next level and attempt it again.
we decided though that this was two one sided of an option and really limits our ability to work with other robots
  #57   Spotlight this post!
Unread 21-01-2015, 15:58
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
I completely agree with this.
We are planning to have a couple of different auto modes for different situations. Depending on our partners' capabilities* I could see our alliance going for 0, 4, 8, or 12 points in auto.
*Their actual capabilities, determined by scouting, not the capabilities that they think they have.
