#16
Re: Need 2014 Driver Station Software
The old Java libraries would have to be updated to support the new Network Communications API to read joysticks and tele-op / auto mode selections and the like (the same way LabVIEW for the cRIO was). Other than that it should work with the Net Beans tools.
#18
We program in Labview, and I really don't want to have both 2014 and 2015 driver station software on our DS laptop. What do I need to do?
Do I have to re-deploy my 2014 robot code from the 2015 software? CAN I re-deploy 2014 from 2015, or would I have to re-write the program in 2015 Labview? Will I need to re-image first? Is there anything else? To me this seems like the kind of ordinary functionality that tons of teams would need to have, to continue demonstrating their old robots this year...if it is so difficult, then why is there not a step by step instruction provided with the title "How to run your old robots from the new driver station software" |
#20
The 2014 and 2015 Driver Station programs coexist without conflict (though I think the 2015 installer erases the contents of the folder, so you have to install the 2014 one last). |
#21
And the 2014 installer overwrites the 2015 dashboard so you should rename the 2015 dashboard first if you want to keep it.
#22
Can I open and deploy the program that we wrote in 2014 Labview with 2015 Labview, or do we need to re-write last year's program in the new software? |
#23
You shouldn't need to rewrite all of your code, but you should look at the indices in Begin and update them to be zero based. There may be some other areas such as the compressor that you need to look at.
Work on a copy of the code, and you should find out within a few minutes whether you will have issues or not. Greg McKaskle |
#24
There is a solution that doesn't require any code change. Don't change any of the tools used for the robot and everything still works.
If you have already installed over the DS, zip up the 2015 DS directory, install 2014, rename it, and unzip the 2015 one. Unless there is just a ton of code from 2014, it probably won't take but a few hours to upgrade to 2015, but this gives your team options. Greg McKaskle |
