Go to Post If they don't treat Dave nicely, he may just keep his big red ball, and not share with rest of us. - Barry Bonzack [more]
Unread 21-01-2015, 15:23
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Clippard Air Tank Leaking
Originally Posted by adciv View Post
Have you traced where the leaks are occurring? Below is how we find pneumatics leaks:
1) Take eyedrop bottle of water+dish soap
2) Drop soapy water on *every* pneumatics connection and component in the system (both insertion tubing and threaded fittings).
We've also found all threaded fittings need plumbers tape applied regardless of the way it comes from the manufacturer. Check your solenoids for leaks as well. We use SMCs and have had to tighten ours on the manifolds to eliminate leakage.
^This^
In addition, use the bubble water on ALL pneumatic interfaces, not just the connectors (you'd be amazed at where you'll get leaks).
Also, check to see if your regulator is plumbed backwards (there should be an arrow on the regulators body that shows flow direction).
___________________
- Tennyson, Ulysses
Unread 21-01-2015, 17:43
Hoover's Avatar
Hoover Hoover is offline
no team (None)
Hoover is a name known to allHoover is a name known to allHoover is a name known to allHoover is a name known to allHoover is a name known to allHoover is a name known to all
OK. We needed to test this scientifically. We set up the leaking Clippard. It leaked from both sides. We opened a new one and connected up the same way changing nothing else. No leaks.
We put the old one back on. Leaks as before.
We opened a second new one. No leaks.
Conclusion. Bad air tank. Trashed it.
One thing we noted. The new ones allowed the hoses to be pushed in a bit further.
Unread 21-01-2015, 20:29
Nate Laverdure's Avatar
FRC #2363
Originally Posted by Hoover View Post
The new [tanks] allowed the hoses to be pushed in a bit further. Why? Don't know, don't care.
If you start caring, you might uncover a solution to a systematic problem. That's how an organization builds institutional knowledge.
Strongly suggest building pneumatic systems in phases. Leak-check each phase before expanding the system to the next phase.
Unread 22-01-2015, 10:33
Hoover's Avatar
no team (None)
Sorry I shouldn't've said don't care. Our build was being shortened because of snow warning and I was getting kicked out of the lab...
We compared the tank openings visually. We looked very closely but could see no obstruction to keep the hoses from being fully inserted. And in fact they looked identical. Certainly if there are some tanks that are doing this out there everyone could benefit but I wouldn't know what to tell people to look for other than the insertion distance difference.
Unread 22-01-2015, 16:01
Hoover's Avatar
no team (None)
I noticed the number of views on this thread is high so it seems there are a lot who are interested and it is worth pursuing.
Luckily the trash was not yet thrown out. The plastic tubing went in one side ok and we marked this with a marker and was 3/4 inches. On the other side it hit resistance 1/4 inch sooner and we marked this at 1/2 inches.
I had the kids saw the ends off to get a closer look at how the tubes fit in the openings. Ah ha! Somehow during manufacturing, the plastic entered to opening to cause an obstruction. It can be seen easily when holding the hole up to the light. It is definitely too narrow.
I wish I had a good close up camera to post pictures.
