Go to Post Start building your robot as soon as possible, but not sooner. - Richard Wallace [more]
Unread 21-01-2015, 15:16
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Re: pic: 4242 Preliminary CAD 1
is that a two or three stage lift, and what the goal for stacking, due you really need to go up past the secound level with two totes?
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
mrnoble's Avatar
mrnoble mrnoble is online now
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Originally Posted by apm4242 View Post
the acrylic ramp
Please don't use acrylic.
Unread 21-01-2015, 15:52
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Out of curiosity, why?
Unread 21-01-2015, 15:53
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Prone to shattering, and cracking around bolt holes, even when all it does is support a sponsor decal.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 21-01-2015, 23:16
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Ronnie - Thanks for the input! We have limited experience with chain driven devices. Given the rollers and the carriage track, I'm not sure where we could put a tensioner. However, we might be able to use something like McMaster's Extended-Life Adjustable
Roller Chain Tensioners
on our carriage to tenison it. One or both of the lift axles are going to be on adjustable flange bearings on the tslot. Do you think this will be sufficient to tension the chains?
RE the ramp - Right now, this ramp would only be able to make 1-stacks oriented in a consistent way for others to pick up (basically removing the inconsistencies of the chute). Although, one of our original designs was an articulating conveyor that would make quick 2 and 3-stacks from the tote chute but we nixed it because we didn't have a strong way to drive the cantilevered conveyor and grip was an issue.
That should do the trick. If not, you can always post again and we can give further instructions.
-Ronnie
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 22-01-2015, 08:35
apm4242 apm4242 is offline
FRC #4242
apm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud of
I suppose it's a 1 stage lift? It's chain driven and one side of the chain is anchored to the carriage. As far as height - that's something we're deciding. I'd rather be shorter for stability but it seems silly when all that's limiting how high you can lift is length of tslot and chain (and of course the rules). We don't plan on lifting more than 2-3 totes at a time but we'd like to be able to cap a 3-stack on the platform with a bin. ~38" (3-stacked totes) + ~27"(to the lip of the bin) = 65" off the ground with a bin held by the lip.
We've never had a problem with acrylic but this will be the first year we're considering drilling it. Maybe we'll just slide it into the tslot like last year. The .25" thickness works well with 1010.
Unread 22-01-2015, 08:41
mrnoble's Avatar
teacher/coach
Is polycarbonate (Lexan) not available for you? It will not shatter or crack.
