Go to Post If you plan the work and work the plan, you will very likely make it to the district championship. - IKE [more]
Unread 21-01-2015, 15:53
aewelch aewelch is offline
FRC #4505
aewelch is an unknown quantity at this point
Re: Snow blower motor on motor controller
we have tried both victor and talon and got the same result
Unread 21-01-2015, 16:09
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Er, are you sure that the problem isn't the snowblower motor then?
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 21-01-2015, 16:14
FRC #4505
We have tried sending 12, 7.5 and 5V all directly to the motor and it works fine.
Unread 21-01-2015, 16:40
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Have you put a meter on the controller motor terminals before or while the snowblower motor is connected?
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 22-01-2015, 12:50
FRC #4505
Yes we have put meters on the controllers and are getting the same output before and after. We were thinking it was in the code, but nothing changes in the code from the cim to the snow blower motor? Has anyone actually gotten it to work? All i have found online is many complaints about the motor.
Unread 22-01-2015, 22:25
FRC #4505
Thanks for all your help! we got it to work on the jaguar.
Unread 30-01-2015, 08:18
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
For those folks wondering about Talon SRX and the snow blower motor, we hooked a SB motor up to a Talon SRX last night. We were using CAN bus control but in %voltage mode. The code was in C++. We had Anderson power poles on all of the current carrying connections. When using the Talon SRX demo code, everything worked like a champ. Both forward and backwards through the Talon SRX with no perceivable lag, stutter or any other noticable issues. The Talon was at CAN ID 2, and the PDP was at ID 0. The RoboRIO was running V23 with the F01 firmware.
HTH,
Mike
